Here you go …
RouterOS stripped to essential
# dec/13/2019 06:34:03 by RouterOS 6.46
# software id = TNXU-TVMJ
# model = RouterBOARD 962UiGS-5HacT2HnT
add admin-mac=xx:xx:xx:xx:xx:xx auto-mac=no name=bridge
/interface wireless channels
add band=2ghz-g/n frequency=2412 list=2.4GHZ name=ch1 width=20
add band=2ghz-g/n frequency=2437 list=2.4GHZ name=ch6 width=20
add band=2ghz-g/n frequency=2462 list=2.4GHZ name=ch11 width=20
add authentication-types=wpa2-psk disable-pmkid=yes eap-methods="" \
group-key-update=1h management-protection=allowed mode=dynamic-keys name=\
Fake supplicant-identity=""
/interface wireless
set [ find default-name=wlan1 ] antenna-gain=3 band=2ghz-g/n country=\
netherlands disabled=no disconnect-timeout=15s distance=indoors \
frequency=auto frequency-mode=regulatory-domain installation=indoor mode=\
ap-bridge preamble-mode=long radio-name=hap scan-list=2.4GHZ \
security-profile=Fake ssid=Fake wireless-protocol=802.11 \
wps-mode=disabled
set [ find default-name=wlan2 ] antenna-gain=2 band=5ghz-a/n/ac \
channel-width=20/40mhz-Ce country=netherlands disabled=no frequency=5260 \
frequency-mode=regulatory-domain installation=indoor max-station-count=50 \
mode=ap-bridge preamble-mode=long radio-name=hap security-profile=\
Fake ssid=Fake wireless-protocol=802.11 wps-mode=disabled
add bridge=bridge interface=ether1
add bridge=bridge interface=wlan1
add bridge=bridge interface=wlan2
add bridge=bridge interface=ether2
add bridge=bridge interface=ether3
add bridge=bridge interface=ether4
add bridge=bridge interface=ether5
/ip dhcp-client
add disabled=no interface=bridge
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
output of status 0 on a TH10 with temp sensor
06:44:41 CMD: status 0
06:44:41 MQT: stat/temp3/STATUS = {"Status":{"Module":4,"FriendlyName":["temp3"],"Topic":"temp3","ButtonTopic":"0","Power":1,"PowerOnState":3,"LedState":1,"LedMask":"FFFF","SaveData":1,"SaveState":1,"SwitchTopic":"0","SwitchMode":[0,0,0,0,0,0,0,0],"ButtonRetain":0,"SwitchRetain":0,"SensorRetain":0,"PowerRetain":0}}
06:44:41 MQT: stat/temp3/STATUS1 = {"StatusPRM":{"Baudrate":115200,"GroupTopic":"tasmotas","OtaUrl":"http://thehackbox.org/tasmota/tasmota.bin","RestartReason":"Software/System restart","Uptime":"2T20:16:02","StartupUTC":"2019-12-10T09:28:39","Sleep":50,"CfgHolder":4617,"BootCount":1,"SaveCount":687,"SaveAddress":"F9000"}}
06:44:41 MQT: stat/temp3/STATUS2 = {"StatusFWR":{"Version":"7.1.2.4(3d2e77f-tasmota)","BuildDateTime":"2019-12-09T19:00:09","Boot":31,"Core":"2_6_1","SDK":"2.2.2-dev(38a443e)","Hardware":"ESP8266EX","CR":"245/1151"}}
06:44:41 MQT: stat/temp3/STATUS3 = {"StatusLOG":{"SerialLog":2,"WebLog":2,"MqttLog":0,"SysLog":2,"LogHost":"192.168.6.242","LogPort":1514,"SSId":["Fake",""],"TelePeriod":300,"Resolution":"558180C0","SetOption":["00008009","2805C8000100060000005AFF000000000000","00000000","00000000"]}}
06:44:41 MQT: stat/temp3/STATUS4 = {"StatusMEM":{"ProgramSize":563,"Free":440,"Heap":23,"ProgramFlashSize":1024,"FlashSize":1024,"FlashChipId":"1420C2","FlashMode":3,"Features":["00000809","8FDAE397","043683A0","22B617CD","01001BC0","00007881"],"Drivers":"1,2,3,4,5,6,7,8,9,10,12,16,18,19,20,21,22,24,26,29","Sensors":"1,2,3,4,5,6,7,8,9,10,14,15,17,18,20,22,26,34"}}
06:44:41 MQT: stat/temp3/STATUS5 = {"StatusNET":{"Hostname":"temp3-4394","IPAddress":"192.168.6.171","Gateway":"192.168.6.254","Subnetmask":"255.255.255.0","DNSServer":"192.168.6.246","Mac":"xx:xx:xx:xx:xx:xx","Webserver":2,"WifiConfig":4}}
06:44:41 MQT: stat/temp3/STATUS6 = {"StatusMQT":{"MqttHost":"192.168.6.241","MqttPort":1883,"MqttClientMask":"temp3","MqttClient":"temp3","MqttUser":"DVES_USER","MqttCount":1,"MAX_PACKET_SIZE":1000,"KEEPALIVE":30}}
06:44:41 MQT: stat/temp3/STATUS7 = {"StatusTIM":{"UTC":"Fri Dec 13 05:44:41 2019","Local":"Fri Dec 13 06:44:41 2019","StartDST":"Sun Mar 31 02:00:00 2019","EndDST":"Sun Oct 27 03:00:00 2019","Timezone":"+01:00","Sunrise":"08:35","Sunset":"16:53"}}
06:44:41 MQT: stat/temp3/STATUS10 = {"StatusSNS":{"Time":"2019-12-13T06:44:41","SI7021":{"Temperature":15.0,"Humidity":53.4},"TempUnit":"C"}}
06:44:41 MQT: stat/temp3/STATUS11 = {"StatusSTS":{"Time":"2019-12-13T06:44:41","Uptime":"2T20:16:02","UptimeSec":245762,"Heap":23,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":1,"POWER":"ON","Wifi":{"AP":1,"SSId":"Fake","BSSId":"xx:xx:xx:xx:xx:xx","Channel":1,"RSSI":100,"Signal":-38,"LinkCount":1,"Downtime":"0T00:00:06"}}}
nping output (even tried running with -c 600 and no drops whatsoever …)
nping --arp-type ARP 192.168.6.171 -c 10
Starting Nping 0.7.70 ( https://nmap.org/nping ) at 2019-12-13 06:52 CET
Max rtt: N/A | Min rtt: N/A | Avg rtt: N/A
Raw packets sent: 10 (420B) | Rcvd: 11 (308B) | Lost: 0 (0.00%)
Nping done: 1 IP address pinged in 9.03 seconds
