I have a short question regarding wifi bandwith on my CAP AC via Capsman.
After it suddenly decided to stop at around 95 Mbit/s I rebooted the CAP AC. Then I retested with Iperf against a local server and the speed is up to around 250 Mbit/s on download - when testing upload I can get around 450 Mbit/s.
I was just qurious as to why that is in my mind it should be the same as it is on the same lan the iperf server is, so no firewall rules should be processes.
At what speed is the device connected (both upstream and downstream)?
Differrence is that in the first scenario (download) the accesspoint is the sender and the device the receiver, in the latter its vice versa.
Device is connected with minimum 700 Mbps in RX and TX.
But now it seems we are back to speed somehow being limited to 93 Mbit/s, which is without any changes done to configuration since it worked at 300 Mbit/s.
Got it working again - turns out the solution was simple but sometimes the most obvious is difficult to see
It turned out to be an issue with the cable connecting to the WAP AC, sometimes it went down to 100 Mbps link, which is of course why the speed dropped
So Mikrotik wifi is working again.
