Opinion about wifi blanket like Extricom. Something similar on Mikrotik?
It looks like marketing magic.
If you take off the cover, it looks like they are suggesting that you run all three channels on each floor. (1, 6, 11)
Since they are fully 802.11a/b/g compatible, it just looks like a new twist on deployment.
I suspect you could do the same thing with a RB433 and three radio cards.
Tom
I think if you can control the thin AP’s (using the same channel ) with one routerboard for roaming.
