I have a HAP AC2 that I use as a client bridge, connected via WI-FI to a Huawei 4g router. I configured the bridge with Quick Set and it’s working fine.
I now would like to add a VPN connection to any devices connected to the LAN ports. With my VPN provider I have the option of IKEV2 or WIreguard. IPSEC isn’t available.
Also, if possible I would only like to route traffic between the website servustv.com via the VPN. All other traffic would be connected as normal with no VPN.
I would be really grateful if anyone could give me advice, or point me to a tutorial.
DNS may not be required, unless your ISP does some DNS-based filtering. In that case it would go in system DNS settings, but it can be problematic, because RouterOS has only one common DNS configuration for everything.
