WIFI Bridge with two SXT : fine tuning, bandwith looks a bit low
Hi guys,
I m using two SXT to do a wifi bridge. It works like a charm, but i’m far away from the theory in term of bandwith
Anyone here has any config he did on his wireless that is “optimized” as much as possible, to have the best bandwith possible?
What do you use? 802.1, nstreme etc ?
If you could give me some information on your “optimal” configuration, that would be great :slight_smile:
Thanks a lot!
Physics first. So line of sight, fresnel zone, alignment, signal levels and interference. After that it is fine you don’t need to think about the protocols so much just because it doesn’t work as you would like.
