Wifi Bridge
Hello All Mikrotik users,
I have a situation in my home, and I need your help. Let me explain, I have my main router a mikoritk VM, 1 TP link switch with management and PoE and 3 TP-Link Access points. A standard wifi for a home.
On the Mikroitk router I have 4 vlans:
  • CCTV vlan ID 999
  • Guest vlan ID 99
  • Internet vlan ID 10
  • Management vlan ID 20
All the access points are configured in trunk mode with all vlans and native vlan 20 for management, also there are 3 SSID configured on the access points , a SSID for every vlan, then on the Mikrotik router I have configured the filtering, nat and the firewall as needed.
Now, the problem.
In my office I do not have a ethernet cable, and I need to brig the 4 vlans via Wifi with a Mikrotik hAP.
I tried to setup a station-pseudobridge, i can connect to one wifi, setup the vlan , but I do find any solution to bring all vlans, and then to distribute the vlans in my office as needed.
Dos anyone have a working solution, or this is not possible.
Thank you
Not possible across brands.
Your best bet is
a. to drill (best)
b. to use moca adapters if there is rgb6 coax in the house (okay) Trendnet makes some
c. use powerline adapters over electrical wiring (mileage will vary) best are https://www.techradar.com/news/the-best-powerline-adaptors
