I have trouble in getting my WiFi to work. I am able to connect to the different created WLAN-Networks but I did not receive a IP address from DHCP. The AP is connected on port 7 on my CCR1009. Port 3 to 7 are part of a VLAN-bridge. The VLANs are created and DHCP-Server are created on each VLAN. If I connect with LAN cable to port 4 for example and define that port to be VLAN 50, my device receive an IP from DHCP from VLAN 50. So, in general, VLANs are working (I asume). In my WiFi Setup on the CCR1009 I created different WLAN and add also the VLAN. The Uplink Port handle all VLAN. The AP is running in Caps-Mode.
Looking forward for any help / recommendations
best regards Torsten
