Hello All,
please I need help and I want to buy a new router board + wireless card and i am just wondering .. Is there any wireless card that we can use it on Router Boards …
Also what should I use router board if we have 100 clients connected to our station . I heard of Atheros chipset .. AR5212 Card that can support 2.7 ghz ..
Thank you
by the way i finally finished my antenna that can be on 2.7 ghz so I really need the card .
2.7 Ghz card is not available as i know. But it is planned by Ubiquiti to launch such a card which will support 2.7~2.9Ghz.
Check out their website for more info …
well my maximum frequency would be 2.7 so I can use 2.6 ghz if it is available
what should I use wifi cards ?
That was a bug in the build…
are you sure that we can have 2.6 ghz using ar5212 cards ?
