WiFi compatibility RC1,RC2 & 2.9.x
I have been playing with the new rb333 and rc1,rc2 for a while but cannot make ROSv3 working with 2.9.x - can’t get more than 1Mbps traffic (yes, signal is OK - strength -62, CCQ 100/100%, yes, I tried everything I know).
Is there a proven compatibility issue? If so - when it will be fixed? Sorry but there is more than 200 pieces of rbXXX (and more than 2000 people relying on them) in the network and we can’t afford to switch off whole netowork because of the upgrade to ROS rc2.
Thanks, Hejtmi
yes, there are problems. if you use packet sniffer you will see thousands of extra ACK packets and retransmits going in one direction. I can’t believe this hasn’t come up until now - I ran into this about 2 months ago actually but dismissed it because I thought it was still being worked on in beta stages.
Sam
I have the same problem. Beta working very bad with stable. Customers disconnecting non-stop even with good signal
ime=04:13:22 topics=wireless,info message=00:80:48:41:94:43@OW1: disconnected, extensive data loss
time=04:13:30 topics=wireless,info message=00:80:48:41:94:43@OW2: connected, wants WDS
time=04:14:18 topics=wireless,info message=00:80:48:3F:5D:D5@OW3: disconnected, extensive data loss
time=04:14:26 topics=wireless,info message=00:80:48:3F:5D:D5@OW3: connected, wants WDS
time=04:16:02 topics=wireless,info message=00:80:48:3F:5D:D9@OW1: disconnected, extensive data loss
time=04:16:38 topics=wireless,info message=00:80:48:3F:5D:D9@OW1: connected, wants WDS
What band/frequency?
Which version is AP and which station?
please send the support output files to support@mikrotik.com
Uldis, do you still need some supout? We made the first rb333 deployment yesterday and today and we run in extremely low (average less than 300kbps) throughput when combining RB532 (AP) with 2.9.x (tried 2.9.38 and 2.9.46) and RB333 with RC3.
The wireless link is fine, frequency (5Ghz) does not seem to matter, ping is low and stable, around 4 ms, bandwith test is quite fine (over 4 megs), but real speed is extremely low.
RB333 to RB333 performance is perfectly fine (34 megs hdx, single nstream, 20 mhz channel)
Bye,
Ricky
RC3 looks like it works and the problem was solved… Thank you very much.
It appeared to happen regardless of wireless or wired.
I just jumped back to 2.9.46
you should upgrade to v3.0rc4 which will be out today and then check again.
Thanks uldis, this is very good news..
3.0rc4 is out
… updated the boards.. seems to be fine now, thanks..
