Is Wifi Connect list available in new drivers (qcom-ac)? Somehow i cannot find it.
Sure does.
Can you check that you have the package qcom-ac installed?
/system/package/print
Columns: NAME, VERSION, BUILD-TIME, SIZE
# NAME VERSION BUILD-TIME SIZE
0 wifi-qcom-ac 7.15 2024-05-29 12:44:08 2676.1KiB
1 routeros 7.15 2024-05-29 12:44:08 11.0MiB
Where can i find it? qcom-ac is installed.
[admin@MikroTik] > /system package print
0 routeros 7.15 2024-05-29 12:44:08 11.0MiB
1 wifi-qcom-ac 7.15 2024-05-29 12:44:08 2676.1KiB
In /interface/wifi, for example:
/interface/wifi/print
I don’t think we realy understand each other. I’m searching for a way, to add some Wifi profiles that Mikrotik can use, to connect to other acess points as client. So that i don’t need to change those entries every time i move device to other place with different wifi network.
My bad, I skipped the “… Connect List” somehow.
Beside creating a “station” configuration profile in Capsman, no idea, sorry.
Did you ever figure this out? I think we’re talking about the same thing. I want to use my mAP Lite to act as a backup internet provider connecting to whatever phone hotspot is at home.
I see connect-list which seems to be the right direction, but not sure how to hook this up to my wireless station configuration
Same issue here. I use a device as versatile road warrior opening a Wireguard connection home from whatever ‘known’ AP/SSID is reachable. I can’t find a way to configure this with the new Wifi drivers as there is not ‘connect list’ functionality anymore.
