i’m using a Mikrotik RB5009 and a Mikrotik cAP AX both on on the newest RouterOS Version (7.15.3).
My problem is that my devices always connect and disconnect with my wifi every few minutes.
The problem is the worst on Windows and MacOS Devices.
Sometimes it takes like 30s to connect and often i can’t even connect.
If i can’t connect the wireless, debug log always states: authentication timeout.
I also noticed that most of the time the 5Ghz wifi doesn’t get used, even if I’m in the same room as the AP.
Here is the Wifi Configuration:
/interface wifi channel
add band=2ghz-ax disabled=no name=ch-2ghz width=20mhz
add band=5ghz-ax disabled=no name=ch-5ghz width=20/40/80mhz
/interface wifi security
add authentication-types=wpa2-psk,wpa3-psk connect-priority=0 disabled=no \
name="sec main"
/interface wifi configuration
add country=Italy disabled=no hide-ssid=no mode=ap name=cfg_main security=\
"sec main" ssid=MyWifi
/interface wifi
add channel=ch-2ghz configuration=cfg_main configuration.mode=ap disabled=no \
mtu=1500 name="wifi main 2.4 Ghz" radio-mac=48:A9:8A:E5:07:33
add channel=ch-5ghz configuration=cfg_main configuration.mode=ap disabled=no \
mtu=1500 name="wifi main 5Ghz" radio-mac=48:A9:8A:E5:07:32
Here is the Log Output:
00:12:19 wireless,debug 8A:F8:B3:A3:3C:6C@wifi main 2.4 Ghz associated, signal strength -67
00:12:19 wireless,info 8A:F8:B3:A3:3C:6C@wifi main 2.4 Ghz connected, signal strength -67
00:14:12 wireless,info 8A:F8:B3:A3:3C:6C@wifi main 2.4 Ghz disconnected, connection lost, signal strength -65
00:14:12 wireless,debug 8A:F8:B3:A3:3C:6C@wifi main 2.4 Ghz disassociated, connection lost, signal strength -65
05:30:07 wireless,debug DA:E1:EF:F1:CB:DB@wifi main 2.4 Ghz associated, signal strength -83
05:30:07 wireless,info DA:E1:EF:F1:CB:DB@wifi main 2.4 Ghz connected, signal strength -83
05:50:19 wireless,debug C2:5C:D2:09:C1:40@wifi main 2.4 Ghz associated, signal strength -83
05:50:19 wireless,info C2:5C:D2:09:C1:40@wifi main 2.4 Ghz connected, signal strength -83
06:01:00 wireless,debug 9E:24:0E:F8:F8:0A@wifi main 2.4 Ghz associated, signal strength -69
06:01:00 wireless,info 9E:24:0E:F8:F8:0A@wifi main 2.4 Ghz connected, signal strength -69
06:19:31 wireless,info 9E:24:0E:F8:F8:0A@wifi main 2.4 Ghz disconnected, connection lost, signal strength -89
06:19:31 wireless,debug 9E:24:0E:F8:F8:0A@wifi main 2.4 Ghz disassociated, connection lost, signal strength -89
06:28:35 wireless,info DA:E1:EF:F1:CB:DB@wifi main 2.4 Ghz disconnected, connection lost, signal strength -88
06:28:35 wireless,debug DA:E1:EF:F1:CB:DB@wifi main 2.4 Ghz disassociated, connection lost, signal strength -88
06:29:48 wireless,info C2:5C:D2:09:C1:40@wifi main 2.4 Ghz disconnected, connection lost, signal strength -88
06:29:48 wireless,debug C2:5C:D2:09:C1:40@wifi main 2.4 Ghz disassociated, connection lost, signal strength -88
07:21:51 wireless,debug 8A:F8:B3:A3:3C:6C@wifi main 2.4 Ghz associated, signal strength -68
07:21:51 wireless,info 8A:F8:B3:A3:3C:6C@wifi main 2.4 Ghz connected, signal strength -68
08:14:17 wireless,info 8A:F8:B3:A3:3C:6C@wifi main 2.4 Ghz disconnected, SA Query timeout, signal strength -45
08:14:17 wireless,debug 8A:F8:B3:A3:3C:6C@wifi main 2.4 Ghz disassociated, SA Query timeout, signal strength -45
08:14:17 wireless,debug 8A:F8:B3:A3:3C:6C@wifi main 5Ghz associated, signal strength -52
08:14:17 wireless,info 8A:F8:B3:A3:3C:6C@wifi main 5Ghz connected, signal strength -52
08:40:44 wireless,info 8A:F8:B3:A3:3C:6C@wifi main 5Ghz disconnected, SA Query timeout, signal strength -89
08:40:44 wireless,debug 8A:F8:B3:A3:3C:6C@wifi main 5Ghz disassociated, SA Query timeout, signal strength -89
08:40:44 wireless,debug 8A:F8:B3:A3:3C:6C@wifi main 2.4 Ghz associated, signal strength -73
08:40:45 wireless,info 8A:F8:B3:A3:3C:6C@wifi main 2.4 Ghz connected, signal strength -73
08:44:30 wireless,info 8A:F8:B3:A3:3C:6C@wifi main 2.4 Ghz disconnected, SA Query timeout, signal strength -49
08:44:30 wireless,debug 8A:F8:B3:A3:3C:6C@wifi main 2.4 Ghz disassociated, SA Query timeout, signal strength -49
08:44:30 wireless,debug 8A:F8:B3:A3:3C:6C@wifi main 5Ghz associated, signal strength -50
08:44:31 wireless,info 8A:F8:B3:A3:3C:6C@wifi main 5Ghz connected, signal strength -50
09:01:23 wireless,info 8A:F8:B3:A3:3C:6C@wifi main 5Ghz disconnected, SA Query timeout, signal strength -83
09:01:23 wireless,debug 8A:F8:B3:A3:3C:6C@wifi main 5Ghz disassociated, SA Query timeout, signal strength -83
09:01:24 wireless,debug 8A:F8:B3:A3:3C:6C@wifi main 2.4 Ghz associated, signal strength -76
09:01:24 wireless,info 8A:F8:B3:A3:3C:6C@wifi main 2.4 Ghz connected, signal strength -76
09:01:35 wireless,info 8A:F8:B3:A3:3C:6C@wifi main 2.4 Ghz disconnected, SA Query timeout, signal strength -38
09:01:35 wireless,debug 8A:F8:B3:A3:3C:6C@wifi main 2.4 Ghz disassociated, SA Query timeout, signal strength -38
09:01:35 wireless,debug 8A:F8:B3:A3:3C:6C@wifi main 5Ghz associated, signal strength -40
09:01:35 wireless,info 8A:F8:B3:A3:3C:6C@wifi main 5Ghz connected, signal strength -40
09:20:55 wireless,info 10:D5:61:70:25:09@wifi main 2.4 Ghz disconnected, connection lost, signal strength -87
09:20:55 wireless,debug 10:D5:61:70:25:09@wifi main 2.4 Ghz disassociated, connection lost, signal strength -87
09:21:11 wireless,debug 10:D5:61:70:25:09@wifi main 2.4 Ghz associated, signal strength -90
09:21:11 wireless,info 10:D5:61:70:25:09@wifi main 2.4 Ghz connected, signal strength -90
09:37:09 wireless,info 8A:F8:B3:A3:3C:6C@wifi main 5Ghz disconnected, SA Query timeout, signal strength -88
09:37:09 wireless,debug 8A:F8:B3:A3:3C:6C@wifi main 5Ghz disassociated, SA Query timeout, signal strength -88
09:37:09 wireless,debug 8A:F8:B3:A3:3C:6C@wifi main 2.4 Ghz associated, signal strength -80
09:37:09 wireless,info 8A:F8:B3:A3:3C:6C@wifi main 2.4 Ghz connected, signal strength -80
09:38:27 wireless,info 8A:F8:B3:A3:3C:6C@wifi main 2.4 Ghz disconnected, SA Query timeout, signal strength -71
09:38:27 wireless,debug 8A:F8:B3:A3:3C:6C@wifi main 2.4 Ghz disassociated, SA Query timeout, signal strength -71
09:38:27 wireless,debug 8A:F8:B3:A3:3C:6C@wifi main 5Ghz associated, signal strength -80
09:38:28 wireless,info 8A:F8:B3:A3:3C:6C@wifi main 5Ghz connected, signal strength -80
09:43:35 wireless,info 8A:F8:B3:A3:3C:6C@wifi main 5Ghz disconnected, connection lost, signal strength -88
09:43:35 wireless,debug 8A:F8:B3:A3:3C:6C@wifi main 5Ghz disassociated, connection lost, signal strength -88
11:26:01 wireless,debug DA:E1:EF:F1:CB:DB@wifi main 2.4 Ghz associated, signal strength -85
11:26:02 wireless,info DA:E1:EF:F1:CB:DB@wifi main 2.4 Ghz connected, signal strength -85
11:32:55 wireless,debug 44:23:7C:4F:53:6E@wifi main 2.4 Ghz reauthenticating
11:32:56 wireless,debug 44:23:7C:4F:53:6E@wifi main 2.4 Ghz reauthenticating
11:34:01 wireless,info 10:D5:61:70:25:09@wifi main 2.4 Ghz disconnected, connection lost, signal strength -87
11:34:01 wireless,debug 10:D5:61:70:25:09@wifi main 2.4 Ghz disassociated, connection lost, signal strength -87
12:57:19 wireless,debug 10:D5:61:70:25:09@wifi main 2.4 Ghz associated, signal strength -91
12:57:19 wireless,info 10:D5:61:70:25:09@wifi main 2.4 Ghz connected, signal strength -91
12:59:33 wireless,info 10:D5:61:70:25:09@wifi main 2.4 Ghz disconnected, connection lost, signal strength -87
12:59:33 wireless,debug 10:D5:61:70:25:09@wifi main 2.4 Ghz disassociated, connection lost, signal strength -87
12:59:51 wireless,debug 10:D5:61:70:25:09@wifi main 2.4 Ghz associated, signal strength -89
12:59:51 wireless,info 10:D5:61:70:25:09@wifi main 2.4 Ghz connected, signal strength -89
13:01:33 wireless,info 10:D5:61:70:25:09@wifi main 2.4 Ghz disconnected, connection lost, signal strength -86
13:01:33 wireless,debug 10:D5:61:70:25:09@wifi main 2.4 Ghz disassociated, connection lost, signal strength -86
13:01:56 wireless,debug 10:D5:61:70:25:09@wifi main 2.4 Ghz associated, signal strength -91
13:01:56 wireless,info 10:D5:61:70:25:09@wifi main 2.4 Ghz connected, signal strength -91
13:08:27 wireless,info E2:E3:E6:4C:AB:19@wifi main 5Ghz disconnected, connection lost, signal strength -73
13:08:27 wireless,debug E2:E3:E6:4C:AB:19@wifi main 5Ghz disassociated, connection lost, signal strength -73
14:41:44 wireless,debug 44:23:7C:4F:53:6E@wifi main 2.4 Ghz reauthenticating
15:04:45 wireless,info DA:E1:EF:F1:CB:DB@wifi main 2.4 Ghz disconnected, connection lost, signal strength -86
15:04:45 wireless,debug DA:E1:EF:F1:CB:DB@wifi main 2.4 Ghz disassociated, connection lost, signal strength -86
15:06:46 wireless,debug DA:E1:EF:F1:CB:DB@wifi main 2.4 Ghz associated, signal strength -87
15:06:46 wireless,info DA:E1:EF:F1:CB:DB@wifi main 2.4 Ghz connected, signal strength -87
15:10:52 wireless,debug D6:D0:54:49:0D:69@wifi main 5Ghz associated, signal strength -72
15:10:52 wireless,info D6:D0:54:49:0D:69@wifi main 5Ghz connected, signal strength -75
15:12:23 wireless,info D6:D0:54:49:0D:69@wifi main 5Ghz disconnected, connection lost, signal strength -94
15:12:23 wireless,debug D6:D0:54:49:0D:69@wifi main 5Ghz disassociated, connection lost, signal strength -94
15:12:31 wireless,debug D6:D0:54:49:0D:69@wifi main 2.4 Ghz associated, signal strength -74
15:12:31 wireless,info D6:D0:54:49:0D:69@wifi main 2.4 Ghz connected, signal strength -74
15:24:25 wireless,debug 44:23:7C:4F:53:6E@wifi main 2.4 Ghz reauthenticating
15:39:19 wireless,info D6:D0:54:49:0D:69@wifi main 2.4 Ghz disconnected, connection lost, signal strength -61
15:39:19 wireless,debug D6:D0:54:49:0D:69@wifi main 2.4 Ghz disassociated, connection lost, signal strength -61
15:59:55 wireless,debug 44:23:7C:4F:53:6E@wifi main 2.4 Ghz reauthenticating
16:05:31 wireless,debug D6:D0:54:49:0D:69@wifi main 2.4 Ghz associated, signal strength -58
16:05:31 wireless,info D6:D0:54:49:0D:69@wifi main 2.4 Ghz connected, signal strength -58
16:35:43 wireless,info DA:E1:EF:F1:CB:DB@wifi main 2.4 Ghz disconnected, connection lost, signal strength -88
16:35:43 wireless,debug DA:E1:EF:F1:CB:DB@wifi main 2.4 Ghz disassociated, connection lost, signal strength -88
17:09:10 wireless,debug 8A:F8:B3:A3:3C:6C@wifi main 2.4 Ghz associated, signal strength -70
17:09:10 wireless,info 8A:F8:B3:A3:3C:6C@wifi main 2.4 Ghz connected, signal strength -70
17:09:23 wireless,info 8A:F8:B3:A3:3C:6C@wifi main 2.4 Ghz disconnected, SA Query timeout, signal strength -40
17:09:23 wireless,debug 8A:F8:B3:A3:3C:6C@wifi main 2.4 Ghz disassociated, SA Query timeout, signal strength -40
17:09:23 wireless,debug 8A:F8:B3:A3:3C:6C@wifi main 5Ghz associated, signal strength -44
17:09:23 wireless,info 8A:F8:B3:A3:3C:6C@wifi main 5Ghz connected, signal strength -47
17:18:49 wireless,info D6:D0:54:49:0D:69@wifi main 2.4 Ghz disconnected, connection lost, signal strength -81
17:18:49 wireless,debug D6:D0:54:49:0D:69@wifi main 2.4 Ghz disassociated, connection lost, signal strength -81
17:21:36 wireless,info 8A:F8:B3:A3:3C:6C@wifi main 5Ghz disconnected, SA Query timeout, signal strength -85
17:21:36 wireless,debug 8A:F8:B3:A3:3C:6C@wifi main 5Ghz disassociated, SA Query timeout, signal strength -85
17:21:36 wireless,debug 8A:F8:B3:A3:3C:6C@wifi main 2.4 Ghz associated, signal strength -67
17:21:37 wireless,info 8A:F8:B3:A3:3C:6C@wifi main 2.4 Ghz connected, signal strength -67
17:22:07 wireless,info 8A:F8:B3:A3:3C:6C@wifi main 2.4 Ghz disconnected, SA Query timeout, signal strength -69
17:22:07 wireless,debug 8A:F8:B3:A3:3C:6C@wifi main 2.4 Ghz disassociated, SA Query timeout, signal strength -69
17:22:07 wireless,debug 8A:F8:B3:A3:3C:6C@wifi main 5Ghz associated, signal strength -77
17:22:07 wireless,info 8A:F8:B3:A3:3C:6C@wifi main 5Ghz connected, signal strength -80
17:22:11 wireless,info 8A:F8:B3:A3:3C:6C@wifi main 5Ghz disconnected, SA Query timeout, signal strength -81
17:22:11 wireless,debug 8A:F8:B3:A3:3C:6C@wifi main 5Ghz disassociated, SA Query timeout, signal strength -81
17:22:12 wireless,debug 8A:F8:B3:A3:3C:6C@wifi main 2.4 Ghz associated, signal strength -59
17:22:12 wireless,info 8A:F8:B3:A3:3C:6C@wifi main 2.4 Ghz connected, signal strength -59
17:22:13 wireless,debug 8A:F8:B3:A3:3C:6C@wifi main 5Ghz reauthenticating
17:22:14 wireless,debug 8A:F8:B3:A3:3C:6C@wifi main 5Ghz reauthenticating
17:22:16 wireless,info 8A:F8:B3:A3:3C:6C@wifi main 2.4 Ghz disconnected, SA Query timeout, signal strength -53
17:22:16 wireless,debug 8A:F8:B3:A3:3C:6C@wifi main 2.4 Ghz disassociated, SA Query timeout, signal strength -53
17:22:16 wireless,debug 8A:F8:B3:A3:3C:6C@wifi main 2.4 Ghz associated, signal strength -66
17:22:16 wireless,info 8A:F8:B3:A3:3C:6C@wifi main 2.4 Ghz connected, signal strength -66
17:22:43 wireless,info 8A:F8:B3:A3:3C:6C@wifi main 2.4 Ghz disconnected, SA Query timeout, signal strength -59
17:22:43 wireless,debug 8A:F8:B3:A3:3C:6C@wifi main 2.4 Ghz disassociated, SA Query timeout, signal strength -59
17:22:44 wireless,debug 8A:F8:B3:A3:3C:6C@wifi main 5Ghz associated, signal strength -58
17:22:44 wireless,info 8A:F8:B3:A3:3C:6C@wifi main 5Ghz connected, signal strength -61
17:27:31 wireless,info 8A:F8:B3:A3:3C:6C@wifi main 5Ghz disconnected, SA Query timeout, signal strength -74
17:27:31 wireless,debug 8A:F8:B3:A3:3C:6C@wifi main 5Ghz disassociated, SA Query timeout, signal strength -74
17:27:31 wireless,debug 8A:F8:B3:A3:3C:6C@wifi main 2.4 Ghz associated, signal strength -69
17:27:31 wireless,info 8A:F8:B3:A3:3C:6C@wifi main 2.4 Ghz connected, signal strength -69
17:28:28 wireless,info 8A:F8:B3:A3:3C:6C@wifi main 2.4 Ghz disconnected, connection lost, signal strength -74
17:28:28 wireless,debug 8A:F8:B3:A3:3C:6C@wifi main 2.4 Ghz disassociated, connection lost, signal strength -74
17:29:49 wireless,debug 8A:F8:B3:A3:3C:6C@wifi main 5Ghz associated, signal strength -50
17:29:49 wireless,info 8A:F8:B3:A3:3C:6C@wifi main 5Ghz connected, signal strength -53
17:30:02 wireless,info 8A:F8:B3:A3:3C:6C@wifi main 5Ghz disconnected, SA Query timeout, signal strength -85
17:30:02 wireless,debug 8A:F8:B3:A3:3C:6C@wifi main 5Ghz disassociated, SA Query timeout, signal strength -85
17:30:02 wireless,debug 8A:F8:B3:A3:3C:6C@wifi main 2.4 Ghz associated, signal strength -72
17:30:02 wireless,info 8A:F8:B3:A3:3C:6C@wifi main 2.4 Ghz connected, signal strength -72
17:30:31 wireless,info 8A:F8:B3:A3:3C:6C@wifi main 2.4 Ghz disconnected, SA Query timeout, signal strength -50
17:30:31 wireless,debug 8A:F8:B3:A3:3C:6C@wifi main 2.4 Ghz disassociated, SA Query timeout, signal strength -50
17:30:31 wireless,debug 8A:F8:B3:A3:3C:6C@wifi main 5Ghz associated, signal strength -52
17:30:31 wireless,info 8A:F8:B3:A3:3C:6C@wifi main 5Ghz connected, signal strength -55
17:35:13 wireless,debug D6:D0:54:49:0D:69@wifi main 5Ghz associated, signal strength -76
17:35:14 wireless,info D6:D0:54:49:0D:69@wifi main 5Ghz connected, signal strength -76
17:35:24 wireless,info D6:D0:54:49:0D:69@wifi main 5Ghz disconnected, connection lost, signal strength -92
17:35:24 wireless,debug D6:D0:54:49:0D:69@wifi main 5Ghz disassociated, connection lost, signal strength -92
18:00:06 wireless,debug D6:D0:54:49:0D:69@wifi main 2.4 Ghz associated, signal strength -63
18:00:06 wireless,info D6:D0:54:49:0D:69@wifi main 2.4 Ghz connected, signal strength -63
18:29:50 wireless,info D6:D0:54:49:0D:69@wifi main 2.4 Ghz disconnected, connection lost, signal strength -72
18:29:50 wireless,debug D6:D0:54:49:0D:69@wifi main 2.4 Ghz disassociated, connection lost, signal strength -72
18:30:47 wireless,info 8A:F8:B3:A3:3C:6C@wifi main 5Ghz disconnected, SA Query timeout, signal strength -78
18:30:47 wireless,debug 8A:F8:B3:A3:3C:6C@wifi main 5Ghz disassociated, SA Query timeout, signal strength -78
18:30:47 wireless,debug 8A:F8:B3:A3:3C:6C@wifi main 2.4 Ghz associated, signal strength -64
18:30:47 wireless,info 8A:F8:B3:A3:3C:6C@wifi main 2.4 Ghz connected, signal strength -64
18:34:32 wireless,info 8A:F8:B3:A3:3C:6C@wifi main 2.4 Ghz disconnected, SA Query timeout, signal strength -55
18:34:32 wireless,debug 8A:F8:B3:A3:3C:6C@wifi main 2.4 Ghz disassociated, SA Query timeout, signal strength -55
18:34:32 wireless,debug 8A:F8:B3:A3:3C:6C@wifi main 5Ghz associated, signal strength -82
18:34:33 wireless,info 8A:F8:B3:A3:3C:6C@wifi main 5Ghz connected, signal strength -85
18:35:47 wireless,info 8A:F8:B3:A3:3C:6C@wifi main 5Ghz disconnected, SA Query timeout, signal strength -82
18:35:47 wireless,debug 8A:F8:B3:A3:3C:6C@wifi main 5Ghz disassociated, SA Query timeout, signal strength -82
18:35:47 wireless,debug 8A:F8:B3:A3:3C:6C@wifi main 2.4 Ghz associated, signal strength -64
18:35:48 wireless,info 8A:F8:B3:A3:3C:6C@wifi main 2.4 Ghz connected, signal strength -64
18:46:30 wireless,info 8A:F8:B3:A3:3C:6C@wifi main 2.4 Ghz disconnected, SA Query timeout, signal strength -49
18:46:30 wireless,debug 8A:F8:B3:A3:3C:6C@wifi main 2.4 Ghz disassociated, SA Query timeout, signal strength -49
18:46:30 wireless,debug 8A:F8:B3:A3:3C:6C@wifi main 5Ghz associated, signal strength -50
18:46:30 wireless,info 8A:F8:B3:A3:3C:6C@wifi main 5Ghz connected, signal strength -53
19:14:23 wireless,debug DA:E1:EF:F1:CB:DB@wifi main 2.4 Ghz associated, signal strength -77
19:14:23 wireless,info DA:E1:EF:F1:CB:DB@wifi main 2.4 Ghz connected, signal strength -77
19:22:03 wireless,debug C2:5C:D2:09:C1:40@wifi main 2.4 Ghz associated, signal strength -77
19:22:04 wireless,info C2:5C:D2:09:C1:40@wifi main 2.4 Ghz connected, signal strength -77
19:49:55 wireless,info 8A:F8:B3:A3:3C:6C@wifi main 5Ghz disconnected, SA Query timeout, signal strength -73
19:49:55 wireless,debug 8A:F8:B3:A3:3C:6C@wifi main 5Ghz disassociated, SA Query timeout, signal strength -73
19:49:55 wireless,debug 8A:F8:B3:A3:3C:6C@wifi main 2.4 Ghz associated, signal strength -74
19:49:55 wireless,info 8A:F8:B3:A3:3C:6C@wifi main 2.4 Ghz connected, signal strength -74
19:50:02 wireless,debug 8A:F8:B3:A3:3C:6C@wifi main 5Ghz authentication timeout
19:50:44 wireless,info 8A:F8:B3:A3:3C:6C@wifi main 2.4 Ghz disconnected, SA Query timeout, signal strength -59
19:50:44 wireless,debug 8A:F8:B3:A3:3C:6C@wifi main 2.4 Ghz disassociated, SA Query timeout, signal strength -59
19:50:45 wireless,debug 8A:F8:B3:A3:3C:6C@wifi main 5Ghz associated, signal strength -72
19:50:45 wireless,info 8A:F8:B3:A3:3C:6C@wifi main 5Ghz connected, signal strength -75
19:50:47 wireless,info 8A:F8:B3:A3:3C:6C@wifi main 5Ghz disconnected, SA Query timeout, signal strength -75
19:50:47 wireless,debug 8A:F8:B3:A3:3C:6C@wifi main 5Ghz disassociated, SA Query timeout, signal strength -75
19:50:47 wireless,debug 8A:F8:B3:A3:3C:6C@wifi main 2.4 Ghz associated, signal strength -66
19:50:47 wireless,info 8A:F8:B3:A3:3C:6C@wifi main 2.4 Ghz connected, signal strength -66
19:50:52 wireless,info 8A:F8:B3:A3:3C:6C@wifi main 2.4 Ghz disconnected, SA Query timeout, signal strength -56
19:50:52 wireless,debug 8A:F8:B3:A3:3C:6C@wifi main 2.4 Ghz disassociated, SA Query timeout, signal strength -56
19:50:52 wireless,debug 8A:F8:B3:A3:3C:6C@wifi main 5Ghz associated, signal strength -69
19:50:52 wireless,info 8A:F8:B3:A3:3C:6C@wifi main 5Ghz connected, signal strength -72
19:51:19 wireless,info 8A:F8:B3:A3:3C:6C@wifi main 5Ghz disconnected, SA Query timeout, signal strength -82
19:51:19 wireless,debug 8A:F8:B3:A3:3C:6C@wifi main 5Ghz disassociated, SA Query timeout, signal strength -82
19:51:19 wireless,debug 8A:F8:B3:A3:3C:6C@wifi main 2.4 Ghz associated, signal strength -69
19:51:19 wireless,info 8A:F8:B3:A3:3C:6C@wifi main 2.4 Ghz connected, signal strength -69
19:51:31 wireless,info 8A:F8:B3:A3:3C:6C@wifi main 2.4 Ghz disconnected, SA Query timeout, signal strength -65
19:51:31 wireless,debug 8A:F8:B3:A3:3C:6C@wifi main 2.4 Ghz disassociated, SA Query timeout, signal strength -65
19:51:31 wireless,debug 8A:F8:B3:A3:3C:6C@wifi main 5Ghz associated, signal strength -62
19:51:31 wireless,info 8A:F8:B3:A3:3C:6C@wifi main 5Ghz connected, signal strength -65
19:52:15 wireless,info 8A:F8:B3:A3:3C:6C@wifi main 5Ghz disconnected, SA Query timeout, signal strength -78
19:52:15 wireless,debug 8A:F8:B3:A3:3C:6C@wifi main 5Ghz disassociated, SA Query timeout, signal strength -78
19:52:16 wireless,debug 8A:F8:B3:A3:3C:6C@wifi main 2.4 Ghz associated, signal strength -73
19:52:16 wireless,info 8A:F8:B3:A3:3C:6C@wifi main 2.4 Ghz connected, signal strength -73
19:52:17 wireless,info 8A:F8:B3:A3:3C:6C@wifi main 2.4 Ghz disconnected, SA Query timeout, signal strength -60
19:52:17 wireless,debug 8A:F8:B3:A3:3C:6C@wifi main 2.4 Ghz disassociated, SA Query timeout, signal strength -60
19:52:18 wireless,debug 8A:F8:B3:A3:3C:6C@wifi main 5Ghz associated, signal strength -66
19:52:18 wireless,info 8A:F8:B3:A3:3C:6C@wifi main 5Ghz connected, signal strength -69
19:52:31 wireless,info 8A:F8:B3:A3:3C:6C@wifi main 5Ghz disconnected, SA Query timeout, signal strength -92
19:52:31 wireless,debug 8A:F8:B3:A3:3C:6C@wifi main 5Ghz disassociated, SA Query timeout, signal strength -92
19:52:32 wireless,debug 8A:F8:B3:A3:3C:6C@wifi main 2.4 Ghz associated, signal strength -80
19:52:32 wireless,info 8A:F8:B3:A3:3C:6C@wifi main 2.4 Ghz connected, signal strength -80
19:54:01 wireless,debug 94:E7:0B:E3:0D:D7@wifi main 2.4 Ghz assocation rejected, cant find PMKSA
19:54:01 wireless,debug 94:E7:0B:E3:0D:D7@wifi main 2.4 Ghz associated, signal strength -67
19:54:02 wireless,info 94:E7:0B:E3:0D:D7@wifi main 2.4 Ghz connected, signal strength -68
19:54:42 wireless,info 94:E7:0B:E3:0D:D7@wifi main 2.4 Ghz disconnected, connection lost, signal strength -68
19:54:42 wireless,debug 94:E7:0B:E3:0D:D7@wifi main 2.4 Ghz disassociated, connection lost, signal strength -68
19:55:25 wireless,debug 94:E7:0B:E3:0D:D7@wifi main 2.4 Ghz associated, signal strength -75
19:55:25 wireless,info 94:E7:0B:E3:0D:D7@wifi main 2.4 Ghz connected, signal strength -75
20:03:22 wireless,debug 9E:24:0E:F8:F8:0A@wifi main 2.4 Ghz associated, signal strength -65
20:03:23 wireless,info 9E:24:0E:F8:F8:0A@wifi main 2.4 Ghz connected, signal strength -65
20:03:36 wireless,info 9E:24:0E:F8:F8:0A@wifi main 2.4 Ghz disconnected, SA Query timeout, signal strength -68
20:03:36 wireless,debug 9E:24:0E:F8:F8:0A@wifi main 2.4 Ghz disassociated, SA Query timeout, signal strength -68
20:03:40 wireless,debug 9E:24:0E:F8:F8:0A@wifi main 2.4 Ghz associated, signal strength -72
20:03:40 wireless,info 9E:24:0E:F8:F8:0A@wifi main 2.4 Ghz connected, signal strength -72
20:03:58 wireless,info 8A:F8:B3:A3:3C:6C@wifi main 2.4 Ghz disconnected, connection lost, signal strength -74
20:03:58 wireless,debug 8A:F8:B3:A3:3C:6C@wifi main 2.4 Ghz disassociated, connection lost, signal strength -74
20:04:00 wireless,info 9E:24:0E:F8:F8:0A@wifi main 2.4 Ghz disconnected, SA Query timeout, signal strength -66
20:04:00 wireless,debug 9E:24:0E:F8:F8:0A@wifi main 2.4 Ghz disassociated, SA Query timeout, signal strength -66
20:04:05 wireless,debug 9E:24:0E:F8:F8:0A@wifi main 5Ghz associated, signal strength -72
20:04:05 wireless,info 9E:24:0E:F8:F8:0A@wifi main 5Ghz connected, signal strength -75
20:04:14 wireless,info 9E:24:0E:F8:F8:0A@wifi main 5Ghz disconnected, SA Query timeout, signal strength -84
20:04:14 wireless,debug 9E:24:0E:F8:F8:0A@wifi main 5Ghz disassociated, SA Query timeout, signal strength -84
20:04:14 wireless,debug 9E:24:0E:F8:F8:0A@wifi main 2.4 Ghz associated, signal strength -66
20:04:14 wireless,info 9E:24:0E:F8:F8:0A@wifi main 2.4 Ghz connected, signal strength -66
20:06:34 wireless,debug 8A:F8:B3:A3:3C:6C@wifi main 5Ghz associated, signal strength -57
20:06:34 wireless,info 8A:F8:B3:A3:3C:6C@wifi main 5Ghz connected, signal strength -60
20:07:19 wireless,info 8A:F8:B3:A3:3C:6C@wifi main 5Ghz disconnected, SA Query timeout, signal strength -92
20:07:19 wireless,debug 8A:F8:B3:A3:3C:6C@wifi main 5Ghz disassociated, SA Query timeout, signal strength -92
20:07:20 wireless,debug 8A:F8:B3:A3:3C:6C@wifi main 2.4 Ghz associated, signal strength -70
20:07:20 wireless,info 8A:F8:B3:A3:3C:6C@wifi main 2.4 Ghz connected, signal strength -70
20:42:58 wireless,info 8A:F8:B3:A3:3C:6C@wifi main 2.4 Ghz disconnected, connection lost, signal strength -74
20:42:58 wireless,debug 8A:F8:B3:A3:3C:6C@wifi main 2.4 Ghz disassociated, connection lost, signal strength -74
20:54:42 wireless,info 10:D5:61:70:25:09@wifi main 2.4 Ghz disconnected, connection lost, signal strength -88
20:54:42 wireless,debug 10:D5:61:70:25:09@wifi main 2.4 Ghz disassociated, connection lost, signal strength -88
20:54:46 wireless,debug E2:E3:E6:4C:AB:19@wifi main 5Ghz associated, signal strength -75
20:54:46 wireless,info E2:E3:E6:4C:AB:19@wifi main 5Ghz connected, signal strength -78
20:55:17 wireless,debug 10:D5:61:70:25:09@wifi main 2.4 Ghz associated, signal strength -92
20:55:17 wireless,info 10:D5:61:70:25:09@wifi main 2.4 Ghz connected, signal strength -92
20:55:25 wireless,info 10:D5:61:70:25:09@wifi main 2.4 Ghz disconnected, connection lost, signal strength -88
20:55:25 wireless,debug 10:D5:61:70:25:09@wifi main 2.4 Ghz disassociated, connection lost, signal strength -88
20:55:44 wireless,debug 10:D5:61:70:25:09@wifi main 2.4 Ghz associated, signal strength -92
20:55:45 wireless,info 10:D5:61:70:25:09@wifi main 2.4 Ghz connected, signal strength -92
20:56:24 wireless,info 94:E7:0B:E3:0D:D7@wifi main 2.4 Ghz disconnected, connection lost, signal strength -76
20:56:24 wireless,debug 94:E7:0B:E3:0D:D7@wifi main 2.4 Ghz disassociated, connection lost, signal strength -76
20:56:58 wireless,debug E2:E3:E6:4C:AB:19@wifi main 5Ghz reauthenticating
20:56:59 wireless,info E2:E3:E6:4C:AB:19@wifi main 5Ghz disconnected, SA Query timeout, signal strength -74
20:56:59 wireless,debug E2:E3:E6:4C:AB:19@wifi main 5Ghz disassociated, SA Query timeout, signal strength -74
20:57:00 wireless,debug E2:E3:E6:4C:AB:19@wifi main 5Ghz associated, signal strength -67
20:57:00 wireless,debug E2:E3:E6:4C:AB:19@wifi main 5Ghz disassociated, connection lost, signal strength -67
20:57:01 wireless,debug E2:E3:E6:4C:AB:19@wifi main 5Ghz associated, signal strength -65
20:57:06 wireless,debug E2:E3:E6:4C:AB:19@wifi main 5Ghz disassociated, connection lost, signal strength -68
20:57:13 wireless,debug E2:E3:E6:4C:AB:19@wifi main 5Ghz authentication timeout
20:57:18 wireless,debug E2:E3:E6:4C:AB:19@wifi main 5Ghz authentication timeout
20:57:29 wireless,debug E2:E3:E6:4C:AB:19@wifi main 5Ghz authentication timeout
20:57:36 wireless,debug E2:E3:E6:4C:AB:19@wifi main 5Ghz authentication timeout
20:57:55 wireless,debug E2:E3:E6:4C:AB:19@wifi main 5Ghz authentication timeout
20:58:00 wireless,debug E2:E3:E6:4C:AB:19@wifi main 5Ghz authentication timeout
20:58:55 wireless,debug E2:E3:E6:4C:AB:19@wifi main 5Ghz associated, signal strength -70
20:59:00 wireless,debug E2:E3:E6:4C:AB:19@wifi main 5Ghz disassociated, connection lost, signal strength -73
20:59:01 wireless,debug E2:E3:E6:4C:AB:19@wifi main 5Ghz associated, signal strength -68
20:59:06 wireless,debug E2:E3:E6:4C:AB:19@wifi main 5Ghz disassociated, connection lost, signal strength -71
20:59:13 wireless,debug E2:E3:E6:4C:AB:19@wifi main 5Ghz authentication timeout
20:59:15 wireless,debug E2:E3:E6:4C:AB:19@wifi main 2.4 Ghz authentication timeout
20:59:22 wireless,debug E2:E3:E6:4C:AB:19@wifi main 5Ghz authentication timeout
20:59:23 wireless,debug 8A:F8:B3:A3:3C:6C@wifi main 2.4 Ghz associated, signal strength -64
20:59:24 wireless,info 8A:F8:B3:A3:3C:6C@wifi main 2.4 Ghz connected, signal strength -64
20:59:25 wireless,debug E2:E3:E6:4C:AB:19@wifi main 2.4 Ghz authentication timeout
20:59:28 wireless,debug E2:E3:E6:4C:AB:19@wifi main 5Ghz authentication timeout
20:59:30 wireless,debug E2:E3:E6:4C:AB:19@wifi main 2.4 Ghz authentication timeout
20:59:36 wireless,debug E2:E3:E6:4C:AB:19@wifi main 5Ghz authentication timeout
20:59:38 wireless,debug E2:E3:E6:4C:AB:19@wifi main 2.4 Ghz authentication timeout
20:59:38 wireless,debug E2:E3:E6:4C:AB:19@wifi main 5Ghz associated, signal strength -64
20:59:43 wireless,debug E2:E3:E6:4C:AB:19@wifi main 5Ghz disassociated, connection lost, signal strength -70
20:59:50 wireless,debug E2:E3:E6:4C:AB:19@wifi main 5Ghz authentication timeout
20:59:52 wireless,debug E2:E3:E6:4C:AB:19@wifi main 2.4 Ghz authentication timeout
21:00:00 wireless,debug E2:E3:E6:4C:AB:19@wifi main 5Ghz authentication timeout
21:00:02 wireless,debug E2:E3:E6:4C:AB:19@wifi main 2.4 Ghz authentication timeout
21:00:14 wireless,debug E2:E3:E6:4C:AB:19@wifi main 5Ghz authentication timeout
21:00:16 wireless,debug E2:E3:E6:4C:AB:19@wifi main 2.4 Ghz authentication timeout
21:00:21 wireless,debug E2:E3:E6:4C:AB:19@wifi main 5Ghz authentication timeout
21:00:23 wireless,debug E2:E3:E6:4C:AB:19@wifi main 2.4 Ghz authentication timeout
21:00:28 wireless,debug E2:E3:E6:4C:AB:19@wifi main 5Ghz associated, signal strength -62
21:00:33 wireless,debug E2:E3:E6:4C:AB:19@wifi main 5Ghz disassociated, connection lost, signal strength -65
21:00:38 wireless,debug E2:E3:E6:4C:AB:19@wifi main 5Ghz authentication timeout
21:00:41 wireless,debug E2:E3:E6:4C:AB:19@wifi main 2.4 Ghz authentication timeout
21:00:46 wireless,debug E2:E3:E6:4C:AB:19@wifi main 5Ghz authentication timeout
21:00:47 wireless,debug E2:E3:E6:4C:AB:19@wifi main 5Ghz associated, signal strength -62
21:00:49 wireless,debug E2:E3:E6:4C:AB:19@wifi main 2.4 Ghz authentication timeout
21:00:52 wireless,debug E2:E3:E6:4C:AB:19@wifi main 5Ghz disassociated, connection lost, signal strength -66
21:00:59 wireless,debug E2:E3:E6:4C:AB:19@wifi main 5Ghz authentication timeout
21:01:01 wireless,debug E2:E3:E6:4C:AB:19@wifi main 2.4 Ghz authentication timeout
21:01:04 wireless,debug E2:E3:E6:4C:AB:19@wifi main 5Ghz authentication timeout
21:01:07 wireless,debug E2:E3:E6:4C:AB:19@wifi main 2.4 Ghz authentication timeout
21:01:12 wireless,info 10:D5:61:70:25:09@wifi main 2.4 Ghz disconnected, connection lost, signal strength -88
21:01:12 wireless,debug 10:D5:61:70:25:09@wifi main 2.4 Ghz disassociated, connection lost, signal strength -88
21:01:18 wireless,debug E2:E3:E6:4C:AB:19@wifi main 5Ghz authentication timeout
21:01:20 wireless,debug E2:E3:E6:4C:AB:19@wifi main 2.4 Ghz authentication timeout
21:01:27 wireless,debug E2:E3:E6:4C:AB:19@wifi main 5Ghz authentication timeout
21:01:30 wireless,debug E2:E3:E6:4C:AB:19@wifi main 2.4 Ghz authentication timeout
21:01:45 wireless,debug E2:E3:E6:4C:AB:19@wifi main 5Ghz authentication timeout
21:01:48 wireless,debug E2:E3:E6:4C:AB:19@wifi main 2.4 Ghz authentication timeout
21:01:52 wireless,debug E2:E3:E6:4C:AB:19@wifi main 5Ghz authentication timeout
21:01:54 wireless,debug E2:E3:E6:4C:AB:19@wifi main 2.4 Ghz authentication timeout
21:02:01 wireless,debug 10:D5:61:70:25:09@wifi main 2.4 Ghz associated, signal strength -91
21:02:01 wireless,info 10:D5:61:70:25:09@wifi main 2.4 Ghz connected, signal strength -91
21:02:02 wireless,debug E2:E3:E6:4C:AB:19@wifi main 5Ghz authentication timeout
21:02:05 wireless,debug E2:E3:E6:4C:AB:19@wifi main 2.4 Ghz authentication timeout
21:02:10 wireless,debug E2:E3:E6:4C:AB:19@wifi main 5Ghz authentication timeout
21:02:13 wireless,debug E2:E3:E6:4C:AB:19@wifi main 2.4 Ghz authentication timeout
21:02:13 wireless,debug E2:E3:E6:4C:AB:19@wifi main 5Ghz associated, signal strength -68
21:02:18 wireless,debug E2:E3:E6:4C:AB:19@wifi main 5Ghz disassociated, connection lost, signal strength -72
21:02:24 wireless,debug E2:E3:E6:4C:AB:19@wifi main 5Ghz authentication timeout
21:02:27 wireless,debug E2:E3:E6:4C:AB:19@wifi main 2.4 Ghz authentication timeout
21:02:34 wireless,debug E2:E3:E6:4C:AB:19@wifi main 5Ghz authentication timeout
21:02:36 wireless,debug E2:E3:E6:4C:AB:19@wifi main 2.4 Ghz authentication timeout
21:02:53 wireless,debug E2:E3:E6:4C:AB:19@wifi main 5Ghz authentication timeout
21:02:56 wireless,debug E2:E3:E6:4C:AB:19@wifi main 2.4 Ghz authentication timeout
21:03:01 wireless,debug E2:E3:E6:4C:AB:19@wifi main 5Ghz authentication timeout
21:03:02 wireless,debug E2:E3:E6:4C:AB:19@wifi main 5Ghz associated, signal strength -62
21:03:03 wireless,debug E2:E3:E6:4C:AB:19@wifi main 2.4 Ghz authentication timeout
21:03:07 wireless,debug E2:E3:E6:4C:AB:19@wifi main 5Ghz disassociated, connection lost, signal strength -65
21:03:13 wireless,debug E2:E3:E6:4C:AB:19@wifi main 5Ghz authentication timeout
21:03:16 wireless,debug E2:E3:E6:4C:AB:19@wifi main 2.4 Ghz authentication timeout
21:03:21 wireless,debug E2:E3:E6:4C:AB:19@wifi main 5Ghz authentication timeout
21:03:23 wireless,debug E2:E3:E6:4C:AB:19@wifi main 2.4 Ghz authentication timeout
21:03:40 wireless,debug E2:E3:E6:4C:AB:19@wifi main 5Ghz authentication timeout
21:03:42 wireless,debug E2:E3:E6:4C:AB:19@wifi main 2.4 Ghz authentication timeout
21:03:47 wireless,debug E2:E3:E6:4C:AB:19@wifi main 5Ghz authentication timeout
21:03:49 wireless,debug E2:E3:E6:4C:AB:19@wifi main 2.4 Ghz authentication timeout
21:04:15 wireless,debug A2:EF:2B:99:02:D6@wifi main 5Ghz authentication timeout
21:04:17 wireless,debug A2:EF:2B:99:02:D6@wifi main 2.4 Ghz authentication timeout
21:04:21 wireless,debug A2:EF:2B:99:02:D6@wifi main 5Ghz authentication timeout
21:04:23 wireless,debug A2:EF:2B:99:02:D6@wifi main 2.4 Ghz authentication timeout
