Hello guys, I’ve recently bought two device: cAP AX^2, wAP AX;
I set up capsman for two device, and my iphone can roaming and generate log:
98:xx:xx:xx:xx:xx@wifi1 roamed to 98:xx:xx:xx:xx:xx@cap-wifi2, signal strength -70
98:xx:xx:xx:xx:xx@cap-wifi2 roamed to xx:xx:xx:xx:xx:xx@wifi1, signal strength -73
in /interface/wifi/registration-table
i can found recoad:
mac-address=98:xx:xx:xx:xx:xx auth-type=ft-wpa3-psk
But my other device roam failed, and I’m not sure if they even support roaming.
Also, once they connect, i get /interface/wifi/registration-table :
auth-type=wpa2-psk
they all no “ft-”
So can I say my capsman configuration is OK? just the other device can’t support roaming?
And i tried this:
Win10+AX200 => auth-type=wpa2-psk
Ubuntu+AX200 => auth-type=ft-wpa3-psk
Same laptop. Ubunt can roaming. win10 can’t.
i think this win10 bug.
You are correct. Fast transition is not supported by all devices, by setting connect-priority=0/1 (which is part of the security settings), in my experience, these devices will roam as well.
Thank you for you answer.
for more question.
i have 2 radio.
Columns: NAME, CONFIGURATION.SSID
NAME CONFIGURATION.SSID
1 MDB cap-wifi2 SSID_5G
2 MDB wifi1 SSID_5G
should i set different connect-priority for two wifi?
That depends, can you share your config?
/export file=anynameyoulike
Remove serial and any other private info, post between code tags by using the </> button.
You could change to this:
# 2025-03-03 17:37:12 by RouterOS 7.18
# software id = IYMR-2F6S
# model = C52iG-5HaxD2HaxD
# serial number = ****
/interface wifi
# operated by CAP F4:1E:57:80:5C:5F%bridge1
add name=cap-wifi1 radio-mac=F4:1E:57:80:5C:61
/interface wifi datapath
add bridge=bridge1 disabled=no name=datapath1
/interface wifi security
add authentication-types=wpa2-psk,wpa3-psk disabled=no name=sec1
/interface wifi configuration
add country=China datapath=datapath1 disabled=no hide-ssid=yes name=cfg-2g4 security=sec1 ssid=Aperture-2G4
add country=China datapath=datapath1 disabled=no name=cfg-5G security=sec1 security.connect-priority=0/1 .ft=yes .ft-over-ds=yes ssid=Aperture-5G
/interface wifi capsman
set enabled=yes interfaces=all package-path="" require-peer-certificate=no \
upgrade-policy=none
/interface wifi provisioning
add action=create-dynamic-enabled disabled=no master-configuration=cfg-5G supported-bands=5ghz-ax
add action=create-dynamic-enabled disabled=no master-configuration=cfg-2g4 radio-mac=D4:01:C3:36:15:14 supported-bands=2ghz-ax
There won’t be FT in regards to the 2.4GHz radio (as there is only one involved).
The radio-mac for 2ghz-ax supported bands is unneccesary.
