WiFi disconnecting
I have a strange problem with my two Mikrotik devices (both are running newest RouterOS).
The first one is 2011UiAS-2HnD (it is acting as a router…DHCP, PPPoE and of course WiFi). Wifi is set with the default configuration. I changed SSID and put it on channel 1. Security is WPA2 AES only.
The other device is 951G-2HnD (it was meant only as an AP with WiFi). SSID is the same as on my router, but on channel 11 (same security profile).
On the main router I have set VLAN on port 5 (from there the cable goes to AP on port 1). VLAN is needed for my TV equipment, which is connected on port 2 on AP (multicast traffic).
Problems I am facing is that I am connected to Wifi (router or AP) and suddenly I get disconnected (the wifi shows “No internet”…sometimes I get automatically connected, sometimes not). I have enabled wireless debug logs, but they are not showing anything useful.
When I get disconnected I mostly get these 2 messages in log:
“disconnected, received disassoc: sending station leaving(8)” and “disconnected, group key exchange timeout”.
This is very strange beacuse I am on the internet and I get “received disassoc:…”, so this is not a “power saving” problem as I am using the computer. Sometimes it’s fine for an hour or two, sometimes I get disconnected every 15 mins (this is happening on both Mikrotik devices). The problem is on three different devices which are using the WiFi.
I tried increasing “Group key update” to 1 hour, but this doesn’t resolve my problem. I also tried resetting the wireless configuration.
During tihs writing I got disconnected, I cannot ping the router, I have to manually disconnect and then reconnect.
On AP I have port 1 set as a master, the other ones are slaves. For router I have attached pictures.
Can anyone help me?
Looks like the problem is solved. It was a client issue
