Hi Normis,
Hope you are doing good !
I need your help in fixing wifi connectivity issues in my office. following is the scenario.
Mikrotik Routerboard RB2011U and two Ubiquiti APLR connected to it facilitating 50-60 wifi users on 10Mbps bandwidth.
Some of the time everyday i need to restart the APs because all users get limited connectivity.
Any configuration suggestion will be highly appreciated.
jarda
October 28, 2016, 6:04am
2
Ubiquity is discussed on other forum. This is mikrotik related forum. Please note that.
jarda
October 28, 2016, 6:43am
4
You wrote that the problem is resolved by rebooting of Ubiquity Ap. Nothing that this forum can help you with. Keep it rebooting further, swap them for mikrotik APs or ask Ubiquity forum or support for help with those devices.
Ok, what brand of APs you suggest for Mikrotik for better performance?
jarda
October 28, 2016, 1:15pm
6
I suggest mikrotik brand. But you already have Ubiquity so make it work as it should.
