Wifi Dropped after powering on PC
I have a Hap ac that I’m having some problems with over the last week or so. I use this at home to link a number of items I have togetter and act as a local wif 5Ghz AP. It then links over wifi 2Ghz to a router and my internet.
Its connected via power to my power board that has surge protection. Also connected is my PC etc. When the power button the PC is pressed I find that the 5Ghz is dropped and wifi defices can no longer conect. I have to physcially unpower and repower the unit then its ok. Software reboot dose not work.
Has only just started happening after about six mounts.
I moved its power input to another power let not connected to the surge rail but find same effect. only pysical connection left is the ethernet cable.
Ta
