i simply want to expand my wifi network with MIKROTIK HAP LITE RB941-2ND-TC HOME ACCESS POINT.
How can i do that??
Best Regards
How can i do that??
Best Regards
The device does support WiFi-repeater mode, it can connect to your existing network, and repeat it locally. Results will vary depending on the distance, signal at the location of the hAP unit, and how much speed you require.
How can i connect the device to my existing network? Please tell me the setting i need to change
