I am interested would it be possible to deploy a WiFi network in a sports hall (about 10k visitors) with Mikrotik? If it would, which device would be recommended for Access points?
Thank you very much
Thank you very much
Would that be a mix of indoors and outdoors APs? Do you envision them on walls? On ceilings? Do you plan to manage everything centrally with CAPSMAN?
Can you tell a bit more about how this will be set up?
I am asking if it would be possible in any way.
The sports hall is indoor, with up to 10k people and this should be an event where people should stay at the playground too. Possible mount options are walls and some fences between sitting places and playgrounds but let’s say even celling would be the last option.
If it’s possible with Capsman it would be a good option. I already have a lot of experience with Mikrotik, used to work in WISP and set up a wifi network in companies with a few hundred people but this size - never, especially in this way.
Possible? The answer is yes. Here is a presentation of 2 large scale deployments.
https://mum.mikrotik.com/presentations/EU17/presentation_4063_1490945321.pdf
