I have troubles with login page with hotspot. Galaxy tab is with Android OS. When I try to write a username in the field is not active for writing but password field is active. What can I do with source code for login page to work properly with android OS. With other OS evrything is OK. Thank You a lot.
Regards.
can you post screenshot of the issue? we have not seen any issues with Android devices on hotspot. they can all log in fine.
Did you try upgrading your android?
I work in hotel. We start a hotspot from this summer. And one guest told on reception for this trouble. I saw the problem but i didn’t find a solution for this. He didn’t write in username field. I dont know what is him version of OS. But for future maybe I will have a same problem?
We have tested many android devices, and have not seen such problem. Let me know if you see this ever again.
OK. Thank you.
Hi, i have problems with Android and hotspot
I have a RB 1100 AH, the ethernet ports 6,7,8,9 are hotspots, all devices with iOS, Windows or notebooks run hotspot perfect.
Only Samsung Galaxy and other devices Android doesn’t, what i need to do to work? The config is the default html.
all of them use HTTP
