WiFi in SXT LTE6 kit
Hello Team!
I have one question regarding SXT LTE6 kit.
I’m a little confused, is there a built-in Wi-Fi in this kit?
According to the specifications on the mikrotik site nothing is written about him.
But in the user guide I downloaded from that site there are such points:
7. To personalize your wireless network, SSID can be changed in the fields “Network Name”;
8. Choose your country on the left side of the screen in the field “Country”, to apply country regulation
settings.
9. Set up your wireless network password in the field “WiFi Password” the password must be at least eight
symbols
Thanks for answers.
This device has no Wifi.! Its supposed for remote location with low LTE signal strength.
The WAP 4G KIT (RBwAPR-2nD&R11e-4G) has 2.4Ghz Wifi (same for the LTAP LTE kit).
What you see is RouterOS GUI, which is the same for any Mirkotik product.
Even if the HW might not support some options/interfaces…
Can be miss leading some times …
Hello WeWiNet!
Many thanks for the help.
My colleague and I had disagreements about the availability of Wifi in this device.
Unfortunately, we do not yet have this device to test this in practice.
https://i.mt.lv/cdn/rb_files/1574249866SXT-LTE6%20kit.pdf
True, this information are FALSE.
Device have NOT a wifi interface and this is a error in documentation.
Reported to vendor as: SUP-9191
