Hi all,
I have a strange issue. On my rb922uags-5phacd o also use an r11e 2.4 GHz.
Yesterday after a reboot 5g Wi-Fi network dissappear. In winbox the interface is not present anymore. Is there any way to re-enable this somehow? Or is the interface broken?
Check if its recognized under System > resources > PCI. Can see the image well, have you already checked that?
Check pigtails. ROS will disable interfaces if they too many have errors.
I can see it as unknown. I guess is bad.
Is this warranty problem?
I’d check proper pci card contact, if problem persists, make supout.rif and write to support.
Problem solved. Wireless-fp pkg was disabled. Find out by mistake.
