My WiFi network on RB2011UAS-2HnD-IN has been on for more than 9 months now, without any issue. Mac, iPhones, PC, … connect to it without any problem.
I have now purchased a Samsung Galaxy S4 but after connecting successfully to my WiFI, now and then it disconnects from the network after a few minutes, or sometimes a few hours.
Some Samsung or Android forums mention about possible issues with WiFi and Samsung S4. But I could not really figure out what exactly it was about.
When connecting to a 5 GHz Network on an Apple Airport Extreme, the Samsung keeps the connection without problems.
The problem only arises on my Mikrotik.
Any ideas ?
XX:XX:XX:XX@wlan1:disconnected: extensive data loss
or
XX:XX:XX:XX@wlan1:group key exchange timeout
Last night I tired a trick to switch off WiFi power saving through service mode on my S4
*#1111#
Menu->WiFi → Swich Off WIFI Power Save Mode
Today morning I got Firmware update from Samsung and it looks like the problem is gone.
After firmware update WIFI Power Save Mode is On again.
Some will say this is not related to Mikrotik, but same problems exists on S4 and HTC One that we have in the office,
and it is related to some Routers brands including MikroTik.
Connects to RB 2-3 times longer than to any other access point and then, if the phone was laying with the screen turned off on timeout, can’t communicate over network although WiFi state is “connected”. I have to turn Wi-Fi on the phone off and back on to work further. RB2011UAS-2HnD-IN is the only device it has problems with. (I do not have any other Mikrotik device, so it could be possibly an issue with any Mikrotik device).
It does not depend on WiFi on/off policy and occurs even when it is set to “always on”.
Setting Multicast Helper to Full didn’t help.
Update
The issue seems to be related to DHCP in some way. After I set IP address to static, all the problems are gone. I’ll test it with static IP for another couple of weeks to be sure and then will torture the DHCP in the router.
