WiFi LAG
Hi, I have strange problems with WiFi on RB952Ui-5ac2nD-TC.
14 devices are connected through WiFi.
Most time the signal level is good, pings are short and everything is fine, but time-by-time I have ping LAG to router >3K and connection loss.
As far as I can see, router is not rebooting each time and I do not have any known source of gross interferences.
(Though I have dentist’s office beneath, and they have x-ray)
Could it be possible, that some low voltage input causes bad router signal?
Maybe any other ideas?
This sounds like interference. X-ray will definetively be able to “kill” wifi-signals if the room with the machine is not 100% shielded (which it should be.).
Try getting the dentist to tell you when they use the x-ray next time and do some tests?
It is pretty comically, all local have the same problems and they think that the source of that problem is … Russian embassy nearby)
They have some sort of communication sessions and Ukrainian Security Service monitor them.
As a consequence, all locals experience pattern-less communication problems)
PS: we checked wifi during the work of the only small dentist’s X-Ray - it does not interfere.
OK, maybe they do some sort of jamming when communicating then.
Maybe you should get someone with a scope to document interference for a while then and report to your government, ?
A guy with a scope is a good idea anyway :slight_smile:
