wifi MIKROTIK RouterBOARD hAP (RB951Ui-2nD) very slow while normal cable speed
Hi
I have a mikrotik connected to an orange box. the speed is 200 mb/s. the mikrotik’s wifi struggles to reach 2 mb/s. the flow rate by cable connected to the mikrotik or to the box is normal.
I changed the cat 6 cables, reset the mikrotik, changed the port, replaced the mikrotik with the same model but the result is the same. wifi sucks.
what could be the cause and how to solve it.
THANKS
You should export your configuration and paste it here using code function. Without a configuration it’s hard to say what’s happening.
