Wifi network with double transparent bridge
Hello, we have a problem routing traffic over two transparent bridges. This is our network diagram:
We want 192.168.88.2 to default gateway out the fast internet and access devices on 192.168.88.0/24 (cameras etc.)
The upper part of the network works, but the wifi bridge between 10.0.0.9 and 10.0.0.10 can’t be routed through from either end.
Device 192.168.88.3 can not ping 192.168.88.1 and vice versa, but 10.0.0.10 can ping 192.168.88.1
We currently assume the [bridge]<–>[station-bridge] is the problem, and we should likely have an [ap-bridge] for 10.0.0.10 and a [station-bridge] for 10.0.0.9. Is this assumption correct? We unfortunately only have lvl3 devices there, so we would have to buy a new device for 10.0.0.10.
Any chance we can solve the routing problems if we make 10.0.0.10 [bridge]<–>[station-bridge] 10.0.0.9?
EDIT: Actually I just solved it by switching the bridge around. Not sure if it would be helpful for others to leave this post up?
