wifi password doesnt work for one device
my main router is RB2011UiAS-2HnD. There is another RB951G-2HnD. They are connected via point to point antenas at 14km distance. There was no electricity in the neighbourhood for a couple of hours on the RB2011UiAS-2HnD side. At the time of power shortage my tablet was connected to wifi of RB951G-2HnD.
The problem is I cant connect to RB2011UiAS-2HnD with my tablet anymore. It says Authentication problem. It looks like the password is wrong (it is the right one, no doubt about that). I can connect to RB951G-2HnD with my tablet or any other router with no problem. I tried disconecting RB2011UiAS-2HnD for a minute, restarted the tablet and deleted saved wifi networks on my tablet. No solution.
When I try to connect to wifi I can see the mac address of my tablet for a few seconds on a RB2011UiAS-2HnD admin panel. I did not try to do router hard reset since it was a lot of work to configure the antenas and ip camera.
What else should I try before resetting?
Thank you!
Anyone? If you need more information I’ll gladly provide them.
Have you tried to reset the password?
posicionamiento web economico
So simple yet so effective! Thank You very much.
