wifi problem with apple ios 7.0.2
ihave mikrotik rb751u-2hnd and iphone 5
mikrotik os 5.25 and afte upgrade my ios to 7 every thng work fine
last night i ugrade my phone to ios 7.0.2 and my problem begin. i test it with other os like 5.26 and 6.4 but my issue not solve :frowning:
my problem is only with mikrotik ap device and test with other device it work fine
is there any body have same problem?!
This problem is not related with MikroTik Router OS. you just need to fine tune your wireless settings. Check which wireless protocol you are using?
tnx nawshad
but the only change i made was upgrade my iphone ios from 7 to 7.0.2
and before upgrade my ios i didn’t have any problem.
tnx nawshad
But the only changes that i made was to upgrade my IOS from 7 to 7.0.2, and nothing was changed in my mikrotik.
i didn’t have any problem before the update
Please describe the problem. What exactly is not working ?
my problem: phone (iphone 5 with ios 7.0.2) not connected to wifi ap
does it see the AP in the WiFi list? does it show “connecting” when you tap on it? if yes, what does the RouterOS log file say at this moment?
Hello! azadmehr:
After I update my Iphone IOS 7.02 I also face the same problem today. I search the net and found the solutions.
you need to reset wifi network settings in your Iphone problem will be solved :O)
check this link : http://ipadnerds.com/fix-wifi-issue-ios-7/
good luck
