Wifi Problem!....
Hello from Turkey!
I have this devices;
My Power Over Ethernet;
My modem;
And my Acces Point;
My problem is; With Access Point via a modem using an Ethernet cable to expand the Internet coverage. But I can not do settings. The network name and password. But it does not connect to the network …
Hi. Bridge wifi+ethernet input. make dhcp client on bridge and dhcp relay. after that setup wifi setting.
if you cannot connect try to plug AP to notebook directly
Please do you have winbox or are you using the Internet explorer GUI to configure the device? please send the configuration screen. If u don’t know how to configure. Go to http://www.mikrotik.com/download and scroll down and download winbox and Install it. Then connect the SXT Lan cable to your system and run winbox. The default ip address of your device is: 192.168.88.1. As soon as you can achieve this. Please send the screen shot. We can fix it from there. Hope to hear from you soon.
