WIFI questions regrading to 2 audiences
Hello guys
we are moving to a new office which is much bigger than the current one (Also some walls inside).
So to make sure WiFi can be used all over the new office, we are planning to setup 2 or more Audiences to create a MESH.
The Audiences will be connected to a CISCO switch.
However I have some questions:
  1. For the MESH network, can the user roam from one station to another station without TCP connection disconnected ? For example, on my laptop I am running some apps which connects to server by a TCP connection. I do not want it disconnect then reconnect when I move from one place to another place;
  2. I have go though the docs online. All info is for a ‘Wireless Mesh’ created on the 3rd 5G. Is it possible to create a Wired MESH if we connect the Audiences to the SWITCH with Wired Cable ?
    Thanks.
Mesh networking is inferior to connecting access points to your switch with ethernet. In an office environment, you should really do that.
The clients (laptops) control roaming. They can decide to connect to a stronger signal access point, or decide to stay.
It is perfectly correct to put both access points with the same SSID, and different channels.
