Wifi range extender
Dear MikroTik Community,
im using now for main Wifi a hAP mini and as range extender (like a wireless ap) a hAP lite. I can get around 400-600kb/s download, instead of 6-7MB/s.
Im using it like this, bc the 2.4Ghz of the hAP lite is really shitty, thats why the mini is the main wifi.
I tried different configurations, OS and FW (routeros and routerboard) versions, still the same. Is my hAP lite broken? I get constant lagg in games (yes, this is now for home use,not work) if i use woith the same config, if i use the hap lite. If i change back to hap mini, its almost everytime good. (With hap mini i can get 6-7MB/s)
What should i check, what should i try, my 2.4Ghz is so freakin bad. Now im using bugfix newest version.
Thank you in advance!
