WIFI shown as dynamic [solved]
Routeros 7.20.2
I’m having a weird issue: I think I deleted by mistake one of the wifi interfaces (the 5Ghz one) and it “auto-created” it automatically. May be capsman did it, I’m not sure. The fact is it’s created as “dynamic” (note the D flag) and don’t let me to modify any setting or create a slave. What can I do to restore the normal behavior?
This is the output of print detail for this interface:
3 MDBR default-name="wifi2" name="wifi2" l2mtu=1560 mac-address=DC:2C:xx:xx:xx:xx arp- timeout=auto radio-mac=DC:2C:xx:xx:xx:xx configuration=anv
configuration.ssid="anv"
security.authentication-types=wpa2-psk,wpa3-psk .group-encryption=ccmp .passphrase="xxxxxxxxxx” ft=yes
datapath.bridge=bridge
You can't delete an interface, unless it is virtual or dynamic (AFAIK).
Where is the interface deleted?
Can you share configs involved (CAPsMAN and CAPS?)?
/export file=anynameyoulike
Remove serial and any other private info, post as Preformatted text by using the </> button.
Think you are running 7.20.2, correct? Otherwise, please share your version :slight_smile:
Sorry. Just modified the version. It’s indeed 7.20.2
I’m not sure but I think the problem was because I deleted the interface and it “re-appeared” as dynamic but I’m not sure it’s the cause. What I see is wifi2 is shown as dynamic and I can’t modify it’s settings.
The capsman config is this:
/interface wifi capsman
set enabled=yes interfaces=bridge package-path="" require-peer-certificate=no
upgrade-policy=none
/interface wifi cap
set enabled=yes
I tried also disabling cap in this router because I’m using it as capsman sever so I think it’s not needed here but no change. The 5Ghz interface is still shown as dynamic.
Example:
[admin@MikroTik] /interface/wifi> set [ find default-name=wifi2 ] configuration=anv configuration.country=Spain
failure: can not change dynamic interface
Looks like the interface is (manually) provisioned by the CAPsMAN.
What device are you using? Can you share the output of:
/interface wifi export
To bring a (local) interface back to its initial state, you can reset it by using command:
/interface/wifi reset wifi1
/interface/wifi reset wifi2
Oh yes, you can but not everywhere.
Happened to me already a couple of times with LTE interface.
From what I can see in Winbox you can not with ethernet interfaces (icon to remove is greyed out) but you should be able to with wifi interfaces (icon to remove is selectable).
2025-11-03 11:37:36 by RouterOS 7.20.2
software id = A6N9-5YL6
model = RBD53GR-5HacD2HnD
serial number = xxxxx
/interface wifi securityadd authentication-types=wpa2-psk,wpa3-psk disabled=no encryption=ccmp,gcmp,ccmp-256,gcmp-256 name=sec1/interface wifi
operated by CAP 48:8F:xx:xx:xx:xx%bridge, traffic processing on CAP
add configuration=anv disabled=no name=cap-wifi1 radio-mac=48:8F:xx:xx:xx:xx
add configuration=anv disabled=no name=cap-wifi2 radio-mac=48:8F:xx:xx:xx:xxset [ find default-name=wifi1 ] configuration=anv configuration.country=Spain .mode=ap .ssid=anv disabled=no name=wifi1-2.4 security=sec1 security.ft=yes steering.rrm=yes/interface wifi capset enabled=yes/interface wifi capsmanset enabled=yes interfaces=bridge package-path="" require-peer-certificate=no upgrade-policy=none/interface wifi configurationadd datapath.bridge=bridge disabled=no name=anv security.authentication-types=wpa2-psk,wpa3-psk .encryption=ccmp,gcmp,ccmp-256,gcmp-256 .ft=yes .group-encryption=ccmp ssid=anv/interface wifi datapathadd bridge=bridge disabled=no name=datapath-anv/interface wifi provisioningadd action=create-disabled disabled=no master-configuration=anv
I tried /interface/wifi reset wifi2. The result is this:
[admin@MikroTik] /interface/wifi> /interface/wifi reset wifi2
Well.. Found how to solve the problem.
  1. ensure capsman provision indicates “create enabled” and not “create dynamic enabled”.
  2. go to radios, and provision the one with the problem.
