Wifi speed very low on L900UiGS
I have a optical internet in my country, 825 Mbps by Speedtest with 8ms ping.
On my iPhone 15 Pro only 25Mbps on Speedtest.
Here is my device list on wifi network:
Can you post your full configuration?
How can i export this?
/export file=config
Here is. And sometimes after few minutes my phone showing LTE for 3sec, and after than showing the Wifi bars, when i wake up.
Maybe the connection not consecutive?
config.rsc (7.73 KB)
Another question: is the speed only bad on the iPhone? What is the speed on other devices?
First try:
  1. channel 5500 or 5180
  2. Width=20/40/80mhz
  3. DHCP server lease time 1 day instead of 10 min
Point 1 and 2 are impossible on L009. There is no 5Ghz radio.
What CAN be checked:
use the scanner to see which band is least occupied. Choose that one for L009.
If possible (and if the environment around you is observing the same scheme) stick to 1/6/11 or 1/5/9/13 scheme for channel selection.
Don’t use the widest channel width on 2Ghz, you will only pollute the available channels around you.
Point 1 and 2 are impossible on L009. 2GHz onl
Yes, you are right.
Try use 2412 or 2437 channel and 20 Mhz
With a 20mhz channel OP won’t even get anywhere close his 800mbit line rate…
Correct.
Rule of thumb, what you see in registration window, RX rate, divide by 2.
That’s the max you should get for download speed.
So clearly the wrong choice as access point given that ISP line.
@infabo,
On wifi, and especially 2.4 GHz, in any case there will not be 800 Mbit
I can get REALLY close using 5GHz with AX access points…
With 2Ghz AX I can get to 400Mb (ideal circumstances).
Yes, I completely agree about 5ghz (if it’s AX). With 2.4 800mbit he will not be able to receive it, even if there are no other wifi networks nearby
Yes, in all phone, imac… is same result.
:index_pointing_up:
One more thing: dear OP, the config you posted is from a D53G-5HacD2HnD (Chateau ??).
Where do you see that ?
Here’s the config as posted, including Terminator SSID :laughing: :
# 2024-05-14 19:22:22 by RouterOS 7.14.3
# software id = M89E-D5IX
# model = L009UiGS-2HaxD
# serial number = HFB092GWSF4
add admin-mac=78:9A:18:AA:FC:2F auto-mac=no comment=defconf name=bridge \
    port-cost-mode=short
/interface wifi
set [ find default-name=wifi1 ] channel.band=2ghz-ax .frequency=2300-7300 \
    .secondary-frequency=disabled .width=20/40mhz configuration.country=\
    Hungary .mode=ap .ssid=Skynet disabled=no security.authentication-types=\
    wpa2-psk,wpa3-psk
add comment=defconf name=WAN
add comment=defconf name=LAN
add address-pool=default-dhcp interface=bridge lease-time=10m name=defconf
/ip smb users
/port
set 0 name=serial0
add bridge=bridge comment=defconf interface=ether2 internal-path-cost=10 \
    path-cost=10
add bridge=bridge comment=defconf interface=ether3 internal-path-cost=10 \
    path-cost=10
add bridge=bridge comment=defconf interface=ether4 internal-path-cost=10 \
    path-cost=10
add bridge=bridge comment=defconf interface=ether5 internal-path-cost=10 \
    path-cost=10
add bridge=bridge comment=defconf interface=ether6 internal-path-cost=10 \
    path-cost=10
add bridge=bridge comment=defconf interface=ether7 internal-path-cost=10 \
    path-cost=10
add bridge=bridge comment=defconf interface=ether8 internal-path-cost=10 \
    path-cost=10
add bridge=bridge comment=defconf interface=sfp1 internal-path-cost=10 \
    path-cost=10
add bridge=bridge comment=defconf interface=wifi1 internal-path-cost=10 \
    path-cost=10
set udp-timeout=10s
/interface wifi access-list
add action=accept disabled=no mac-address=00:19:99:CC:D6:41
    192.168.88.0
/ip arp
add address=192.168.88.228 interface=bridge mac-address=00:62:6E:88:93:42
/ip dhcp-client
    192.168.88.1
set allow-remote-requests=yes
/ip dns static
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
/ip service
set telnet disabled=yes
set ftp disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/ip smb shares
set [ find default=yes ] directory=/pub
/ipv6 firewall address-list
/ipv6 firewall filter
    invalid
    icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
    33434-33534 protocol=udp
    udp src-address=fe80::/10
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    500,4500 protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
/system clock
set time-zone-name=Europe/Budapest
/system identity
set name=SkyMicroTik
/system note
set show-at-login=no
/system routerboard settings
set enter-setup-on=delete-key
/system scheduler
add interval=1d name=schedule1 on-event="interface wifi disable wifi1" \
    policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
    start-date=2024-05-12 start-time=22:00:00
add interval=1d name=schedule2 on-event="interface wifi enable wifi1" policy=\
    start-date=2024-05-12 start-time=06:00:00
/tool mac-server
/tool mac-server mac-winbox
OP: do set your frequency FIXED so you KNOW what it will be. Don’t set it to auto or a range.
I am sorry. Wrong downloaded file :disappointed_face:
So, with this kind of settings? Thanks!
