So, when I turn the wifi off and then back on (way later.. like 24 hours later) it is taking the smartphones a while to connect back to the wifi after it’s turned on (like 5 mins).
The phones can see that the wifi is on and get a good signal, but don’t always instantly connect.
I didn’t have this problem when I had a RB951 (of course the wifi range was a lot less on the RB951) , and not the new RB951Ui-2HnD with more powerful signal . Is there something I need to fix or is this how it’s going to be ?
In that case, check the DHCP server. If you’re sure it’s the only (authoritative) DHCP server on the network, set the “authoritative” setting to “yes” instead of the default “after-2sec-delay”.
