Hi all
At home I am running two access points configured via CAPsMAN. It works quite well but I am wondering if I can fine tune it a bit.
What might be a useful information because of the law is that I live in Germany.
Here is my configuration:
caps-man channel print
0 name="home-2.4g" band=2ghz-g/n extension-channel=Ce
1 name="home-5g" band=5ghz-onlyac
caps-man configuration print
0 name="wifiname-2.4g" mode=ap ssid="wifiname" country=germany security=internal security.authentication-types=wpa2-psk datapath=wifi datapath.bridge=wifi-bridge channel=home-2.4g
1 name="wifiname-5g" mode=ap ssid="wifiname5" country=germany security=internal security.authentication-types=wpa2-psk datapath=wifi datapath.bridge=wifi-bridge channel=home-5g
caps-man provisioning print
0 radio-mac=00:00:00:00:00:00 hw-supported-modes=gn identity-regexp="" common-name-regexp="" ip-address-ranges="" action=create-dynamic-enabled master-configuration=wifiname-2.4g slave-configurations="" name-format=prefix-identity name-prefix="2.4"
1 radio-mac=00:00:00:00:00:00 hw-supported-modes=an identity-regexp="" common-name-regexp="" ip-address-ranges="" action=create-dynamic-enabled master-configuration=wifiname-5g slave-configurations="" name-format=prefix-identity name-prefix="5"
I hope that’s all you might need to hint to some improvements.
Thank you in advance!
