WiFi UpLink Solution + Ethernet Downlink
Dear Friends,
I am looking for a solution for a home technological network with WiFi uplink and Ethernet Downlink (Three Ports is enough). I would highly appreciate if you tell a device that can cover these functionality.
Detailed Description:
A router has to support Ethernet Uplink interface with DHCP Client (i.e. DHCP server is a main home router) and WiFi Uplink iterface. A router has to have 3 downlink ethernet ports. Downlink LAN will be with fixed IPs assigned to devices. Uplink network will be with dynamicly assigned IPs by the main home router. No specific requirements for Ethernet interface (10/100 is Ok), load or WiFi.
I look forward to hearing your advice.
You have not mentioned your bandwidth requirements. Start here to see if the hAP ac lite, hAP ac, or RB4011 fit the bill.
