Wifi use by time and mac address
Hello
How i config mikroTik to user wifi use by time and mac address in one day.
Example:
Let the user connect to internet for 2 Hours and then stop internet to the user until next day.
http://forum.mikrotik.com/t/how-can-i-enable-a-device-to-connect-wifi-for-only-2-hours-per-day-without-setting-hotspot/123580/8
Add hotspot
Enable trail,
Set it to 2 hours and you are done
Why would you restrict use of Hotspot users?
I have found out when I do restrict some, they just find other ways to connect to internet and I loose all information on what is going on. (use 3G/4G)
If you do need/want people to go into hotspot splash page etc.
then a simple way without hotspot in firewall: you add IP address to two address lists:
one “allowed” with time-out of 2h
one “wait for renewal” with time out of say 24h (or 6h, whatever you want)
You then drop traffic based on source address list
Important is the below rule order within firewall:
  • accept if in “allowed”
  • drop if in “overtime”
  • add to adress lists with timeout
If you want you can then also clean the address list at midnight via script to have your 24h renewal.
I have never used the mikroTik. So want to know, does it have a function like Parental Control?
