I have my lovely hAP ac with a cable ISP WAN. My devices connect to it using both 2.4 and 5GHz Wifi . I also have an ZTE modem which provides 2.4 Wifi connectivity to itself. Is there a way I can setup up the router to connect to the ZTE modem via WiFi and use it as a backup WAN?
FYI: https://www.youtube.com/watch?v=Ifsb3viu-OM
You can write a scheduled script to check the accessibility of the ISP WAN, and increase the distance of its default route bigger than the default route of the ZTE modem.
Thank you so much, kind sir! That’s exactly what I need - works like a charm!
