Hi There,
Under the old capsman there is a feature where you can set the interval of how often you want each ap to reselect the best channel.
the command was found under the following menu
/capsman configuration channel.reselect-interval
Can anyone confirm if they have found this option in the Wifi Wave2 Capsman ?
The only commands I see are :-
channel.band
channel.frequency
channel.secondary-frequency
channel.skip-dfs-channels
channel.width
Perhaps this feature has not been added to the new capsman yet ?
David
