/wifi (wifiwave2) has inferior AP data
/interface/wifi (wifiwave2) commands (and API data returned) are missing important data to evaluate APs that /interface/wireless has. :frowning:
Are there plans to add some of this information to /wifi?
With /wireless I could just run /wireless/monitor to get signal strength, snr, hertz/channel size, 802.11 standard (e.g. 802.11ac), tx-rate (also p-throughput, ccq), and more.
With /wifi, I have to run multiple commands (API calls) to retrieve that data: /scan (hertz/channel size), frequency-scan (noise floor to then calculate snr), /registration-table (signal strength, tx-rate [no p-throughput, ccq]). Those calls take wall clock time.
/wireless/monitor:
monitor
“.section”: “4”,
“802.1x-port-enabled”: “true”,
“authenticated-clients”: “1”,
“authentication-type”: “wpa2-psk”,
“bridge”: “true”,
“bssid”: “18:FD:74:D3:10:4A”,
“channel”: “5825/20/ac(10dBm)”,
“compression”: “false”,
“current-distance”: “1”,
“encryption”: “aes-ccm”,
“framing-mode”: “none”,
“group-encryption”: “aes-ccm”,
“management-protection”: “false”,
“noise-floor”: “-102”,
“notify-external-fdb”: “false”,
“nstreme”: “false”,
“overall-tx-ccq”: “90”,
“p-throughput”: “79973”,
“radio-name”: “18FD74D3104A”,
“routeros-version”: “7.12rc1”,
“rx-ccq”: “52”,
“rx-rate”: “6Mbps”,
“signal-strength”: “-56”,
“signal-strength-ch0”: “-56”,
“signal-to-noise”: “46”,
“ssid”: “MikroTik-5G”,
“status”: “connected-to-ess”,
“tx-ccq”: “90”,
“tx-rate”: “86.6Mbps-20MHz/1S/SGI”,
“tx-signal-strength”: “-63”,
“tx-signal-strength-ch0”: “-63”,
“wds-link”: “false”,
“wireless-protocol”: “802.11”,
“wmm-enabled”: “true”
/wifi/monitor:
“.section”: “0”,
“ap-address”: “18:FD:74:D3:10:4A”,
“authorized-peers”: “0”,
“available-channels”: “5180/a,5180/n,5180/n/Ce,5180/ac,5180/ac/Ce,5180/ac/Ceee,5180/ax,5180/ax/Ce,5180/ax/Ceee,5200/a,5200/n,5200/n/eC,5200/ac,5200/ac/eC,5200/ac/eCee,5200/ax,5200/ax/eC,5200/ax/eCee,5220/a,5220/n,5220/n/Ce,5220/ac,5220/ac/Ce,5220/ac/eeCe,5220/ax,5220/ax/Ce,5220/ax/eeCe,5240/a,5240/n,5240/n/eC,5240/ac,5240/ac/eC,5240/ac/eeeC,5240/ax,5240/ax/eC,5240/ax/eeeC,5260/a,5260/n,5260/n/Ce,5260/ac,5260/ac/Ce,5260/ac/Ceee,5260/ax,5260/ax/Ce,5260/ax/Ceee,5280/a,5280/n,5280/n/eC,5280/ac,5280/ac/eC,5280/ac/eCee,5280/ax,5280/ax/eC,5280/ax/eCee,5300/a,5300/n,5300/n/Ce,5300/ac,5300/ac/Ce,5300/ac/eeCe,5300/ax,5300/ax/Ce,5300/ax/eeCe,5320/a,5320/n,5320/n/eC,5320/ac,5320/ac/eC,5320/ac/eeeC,5320/ax,5320/ax/eC,5320/ax/eeeC,5500/a,5500/n,5500/n/Ce,5500/ac,5500/ac/Ce,5500/ac/Ceee,5500/ax,5500/ax/Ce,5500/ax/Ceee,5520/a,5520/n,5520/n/eC,5520/ac,5520/ac/eC,5520/ac/eCee,5520/ax,5520/ax/eC,5520/ax/eCee,5540/a,5540/n,5540/n/Ce,5540/ac,5540/ac/Ce,5540/ac/eeCe,5540/ax,5540/ax/Ce,5540/ax/eeCe,5560/a,5560/n,5560/n/eC,5560/ac,5560/ac/eC,5560/ac/eeeC,5560/ax,5560/ax/eC,5560/ax/eeeC,5580/a,5580/n,5580/n/Ce,5580/ac,5580/ac/Ce,5580/ac/Ceee,5580/ax,5580/ax/Ce,5580/ax/Ceee,5600/a,5600/n,5600/n/eC,5600/ac,5600/ac/eC,5600/ac/eCee,5600/ax,5600/ax/eC,5600/ax/eCee,5620/a,5620/n,5620/n/Ce,5620/ac,5620/ac/Ce,5620/ac/eeCe,5620/ax,5620/ax/Ce,5620/ax/eeCe,5640/a,5640/n,5640/n/eC,5640/ac,5640/ac/eC,5640/ac/eeeC,5640/ax,5640/ax/eC,5640/ax/eeeC,5660/a,5660/n,5660/n/Ce,5660/ac,5660/ac/Ce,5660/ac/Ceee,5660/ax,5660/ax/Ce,5660/ax/Ceee,5680/a,5680/n,5680/n/eC,5680/ac,5680/ac/eC,5680/ac/eCee,5680/ax,5680/ax/eC,5680/ax/eCee,5700/a,5700/n,5700/n/Ce,5700/ac,5700/ac/Ce,5700/ac/eeCe,5700/ax,5700/ax/Ce,5700/ax/eeCe,5720/a,5720/n,5720/n/eC,5720/ac,5720/ac/eC,5720/ac/eeeC,5720/ax,5720/ax/eC,5720/ax/eeeC,5745/a,5745/n,5745/n/Ce,5745/ac,5745/ac/Ce,5745/ac/Ceee,5745/ax,5745/ax/Ce,5745/ax/Ceee,5765/a,5765/n,5765/n/eC,5765/ac,5765/ac/eC,5765/ac/eCee,5765/ax,5765/ax/eC,5765/ax/eCee,5785/a,5785/n,5785/n/Ce,5785/ac,5785/ac/Ce,5785/ac/eeCe,5785/ax,5785/ax/Ce,5785/ax/eeCe,5805/a,5805/n,5805/n/eC,5805/ac,5805/ac/eC,5805/ac/eeeC,5805/ax,5805/ax/eC,5805/ax/eeeC,5825/a,5825/n,5825/ac,5825/ax”,
“channel”: “5825/ac”,
“registered-peers”: “0”,
“state”: “authorized”,
“tx-power”: “28”
Yes, wifi drivers lack lots of monitoring data. This was a trend even with legacy wireless driver beginning with ac radio chipsets. And it’s getting worse without prospect of getting better.
You may want to open a ticket with support (use e-mail / support portal). And keep us posted with any replies you might get.
