I merged 2 connections (nth) in RB951Ui,
how can I get wifi work correctly, ( I tried enable it but receive not valid IP address in connected PC)
thanks,
thanks,
Without “/export compact” output, how you can think someone can help you?
thanks rextended,
here it is,
# jan/02/1970 04:20:25 by RouterOS 6.10
# software id = C4P7-U37W
set [ find default-name=ether1 ] name=in1
set [ find default-name=ether2 ] disabled=yes name=in2
set [ find default-name=ether3 ] name=in3
set [ find default-name=ether4 ] name=in4
set [ find default-name=ether5 ] name=out
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n l2mtu=2290 wireless-protocol=\
nv2-nstreme-802.11
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=\
dynamic-keys wpa-pre-shared-key=43CE02EED2CD wpa2-pre-shared-key=\
43CE02EED2CD
/ip hotspot profile
add dns-name=mazen.com hotspot-address=192.10.10.1 name=hsprof1
/ip hotspot user profile
set [ find default=yes ] idle-timeout=none keepalive-timeout=2m \
mac-cookie-timeout=3d
add idle-timeout=none keepalive-timeout=2m mac-cookie-timeout=3d name=monthly \
on-login="{\r\
\n :local date [ /system clock get date ]\r\
\n :if ( [ /ip hotspot user get \$user comment ] = \"\" ) do={\r\
\n [ /ip hotspot user set \$user comment=\$date ]\r\
\n }\r\
\n}"
add name=dhcp_pool1 ranges=192.10.10.2-192.10.10.254
add address-pool=dhcp_pool1 disabled=no interface=out name=dhcp1
/ip hotspot
add address-pool=dhcp_pool1 addresses-per-mac=10 disabled=no interface=out \
name=hotspot1 profile=hsprof1
add address=192.10.10.1/24 interface=out network=192.10.10.0
add address=192.168.1.10/24 interface=wlan1 network=192.168.1.0
/ip dhcp-client
add add-default-route=no dhcp-options=hostname,clientid disabled=no \
interface=in1 use-peer-dns=no use-peer-ntp=no
interface=in2 use-peer-dns=no use-peer-ntp=no
/ip dhcp-server lease
add address=192.10.10.177 client-id=1:cc:52:af:5f:e9:70 mac-address=\
CC:52:AF:5F:E9:70 server=dhcp1
add address=192.10.10.0/24 gateway=192.10.10.1
set servers=8.8.8.8
add action=passthrough chain=unused-hs-chain comment=\
"place hotspot rules here" disabled=yes
/ip firewall mangle
add action=mark-connection chain=prerouting connection-state=new \
new-connection-mark=line1 nth=1,1 src-address=192.10.10.0/24
add action=mark-routing chain=prerouting connection-mark=line1 \
new-routing-mark=line1 src-address=192.10.10.0/24
new-connection-mark=line2 nth=2,2 src-address=192.10.10.0/24
add action=mark-routing chain=prerouting connection-mark=line2 \
new-routing-mark=line2 src-address=192.10.10.0/24
"place hotspot rules here" disabled=yes to-addresses=0.0.0.0
add action=masquerade chain=srcnat comment="masquerade hotspot network" \
src-address=192.10.10.0/24 to-addresses=0.0.0.0
/ip hotspot ip-binding
add address=192.10.10.177 comment="admin (PC home)" mac-address=\
CC:52:AF:5F:E9:70 type=bypassed
add address=192.10.10.29 comment="unc. noor (receiver)" mac-address=\
D2:4A:00:3D:64:7E server=hotspot1 type=bypassed
add address=192.168.88.35 comment=mobile disabled=yes mac-address=\
38:AA:3C:E2:C1:67 type=bypassed
/ip hotspot user
add name=admin
add name=mobi password=0911
add address=192.168.88.177 mac-address=CC:52:AF:5F:E9:70 name="admin home" \
password=0100911
add limit-bytes-total=602931200 limit-uptime=2h36m name=karim password=\
12345678 server=hotspot1
add limit-bytes-total=239097856 limit-uptime=4h22m name=adel password=888 \
server=hotspot1
add comment=jan/02/1970 limit-bytes-total=2147483648 name=dawod600 password=\
666 profile=monthly server=hotspot1
add limit-bytes-total=1258291200 limit-uptime=20h name=mazen password=99999 \
server=hotspot1
add limit-bytes-total=313605120 limit-uptime=4h9m name=tt password=tt server=\
hotspot1
add limit-bytes-total=236978176 limit-uptime=5h name=abosalma password=1183 \
server=hotspot1
add limit-bytes-total=122683392 limit-uptime=1h34m name=salma password=333 \
server=hotspot1
add limit-bytes-total=220200960 limit-uptime=9m name=reda password=999 \
server=hotspot1
add limit-bytes-total=180462336 limit-uptime=8h39m name=menna password=123 \
server=hotspot1
add name=user password=111
add limit-bytes-total=1048576 limit-uptime=6h16m name=remas password=1234 \
server=hotspot1
add limit-uptime=1s name=mariam password=97331 server=hotspot1
add limit-bytes-total=145752064 limit-uptime=3h16m name=sameh77 password=\
51394 server=hotspot1
add limit-bytes-total=1048576 limit-uptime=25m name=mahmoudelfeky password=\
mahmoud server=hotspot1
add limit-bytes-total=1202716672 limit-uptime=18h57m name=hamada password=\
9944 server=hotspot1
add limit-bytes-total=497025024 limit-uptime=7h23m name=elshafey password=\
11223344 server=hotspot1
add name=cell1 password=888
add limit-bytes-total=48234496 limit-uptime=48m name=mohd password=7334 \
server=hotspot1
add limit-bytes-total=314572800 limit-uptime=5h name=rana password=22401 \
server=hotspot1
add distance=1 gateway=192.168.2.1 routing-mark=line1
add distance=1 gateway=192.168.1.1 routing-mark=line2
/ip upnp
set allow-disable-external-interface=no
/system clock
set time-zone-name=Africa/Cairo
/system leds
set 0 interface=wlan1
/system scheduler
add interval=1d name="check monthly users" on-event=manage_monthly policy=\
ftp,reboot,read,write,policy,test,winbox,password,sniff,sensitive,api \
start-date=mar/27/2014 start-time=00:00:00
add interval=12h name="Reboot Router Daily" on-event="/system reboot" policy=\
/system script
add name=manage_monthly policy=\
source="{\r\
\n :local offset 30\r\
\n :global today\r\
\n \r\
\n {\r\
\n :local montharray ( \"jan\",\"feb\",\"mar\",\"apr\",\"may\",\"jun\",\"\
jul\",\"aug\",\"sep\",\"oct\",\"nov\",\"dec\" )\r\
\n :local monthdays ( 31, 28, 31, 30, 31, 30, 31, 31, 30, 31, 30, 31 )\r\
\n :local days [ :pick \$date 4 6 ]\r\
\n :local monthtxt [ :pick \$date 0 3 ]\r\
\n :local year [ :pick \$date 7 11 ]\r\
\n :local months ([ :find \$montharray \$monthtxt] )\r\
\n :for nodays from=0 to=\$months do={\r\
\n :set days ( \$days + [ :pick \$monthdays \$nodays ] )\r\
\n }\r\
\n :set days (\$days + \$year * 365) \r\
\n :set today \$days\r\
\n }\r\
\n \r\
\n :foreach i in [ /ip hotspot user find where disabled=no ] do={\r\
\n :if ([ :find [ /ip hotspot user get \$i comment ] ] = 0 ) do={\r\
\n :local date [ /ip hotspot user get \$i comment ]\r\
\"jul\",\"aug\",\"sep\",\"oct\",\"nov\",\"dec\" )\r\
\n :local months ( [ :find \$montharray \$monthtxt ] )\r\
\n }\r\
\n :set days (\$days + \$year * 365)\r\
\n :if ( (\$days + \$offset) < \$today ) do={ \r\
\n :local name [/ip hotspot user get \$i name]\r\
\n :log info \"HOTSPOT EXPIRE SCRIPT: Disabling Hotspot user \$name fir\
st logged in \$date\"\r\
\n [ /ip hotspot user disable \$i ]\r\
\n [ /ip hotspot active remove [find where user=\$user] ]\r\
\n }\r\
\n }\r\
\n }\r\
\n}"
[…] done, read my following post.
thanks rextended for your help ![]()
Done.
I assume you are on Egypt.
Assuming on your ether1 have internet working, paste this on new terminal and you are able to connect to MATRIX with password 43CE02EED2CD:
/interface wireless
reset-configuration [ find default-name=wlan1 ]
set [ find default-name=wlan1 ] band=2ghz-b/g/n bridge-mode=disabled country=egypt disabled=no frequency=2437 ht-rxchains=0,1 ht-txchains=0,1 max-station-count=30 mode=ap-bridge radio-name=MATRIX security-profile=default wireless-protocol=802.11
add name=pool-dhcp ranges=192.168.120.101-192.168.120.199
add address-pool=pool-dhcp disabled=no interface=wlan1 lease-time=1w name=server-dhcp
remove [find where interface=wlan1]
add address=192.168.120.1/24 interface=wlan1 network=192.168.120.0 disabled=no
add address=192.168.120.0/24 dns-server=192.168.120.1 gateway=192.168.120.1 netmask=24 ntp-server=41.73.42.10,146.231.129.86
set allow-remote-requests=yes cache-max-ttl=1d servers=8.8.8.8,8.8.4.4
add action=masquerade chain=srcnat out-interface=in1 src-address=192.168.120.0/24 disabled=no
add action=masquerade chain=srcnat out-interface=in2 src-address=192.168.120.0/24 disabled=no
/system ntp client
set enabled=yes primary-ntp=41.73.42.10 secondary-ntp=146.231.129.86
:if ( [ /system routerboard get upgrade-firmware ] > [ /system routerboard get current-firmware ] ) do={ /system routerboard upgrade; /delay delay-time=10; /system reboot }
The HotSpot service on ether5 or load balancing remain untouched.
Please let me know if all are working, thanks.
I have internet connections in both ether1 (in1) and ether2 (in2) (just disable in2 for temp time)
are you sure this will not reduce any problems? (when use both in1 and in2)
HotSpot and all other setting remain untouched,
simply set correctly the wlan1, add dhcp server & other parameters for wlan1
You can read line by line, its all understandable.
/interface wireless
reset all wlan1 configuration to defaut
set all working parameters for wlan1
add a separate pool for wlan1
add new dhcp server for wlan1
add new network for dhcp server for wlan1
remove all previous address assigned to wlan1
set new unused address for wlan1
EDIT: ERROR: missing disabled=no
enable DNS request from wlan1
add masquerade to make internet avilable on wlan1 (but not load balance)
/system ntp client
enable NTP for syncronize the clock of RouterBoard
upgrade routerboard BIOS [firmware] to the last version available inside the software (if is needed)
unfortunately, there is no internet access through wifi,
still have internet access through “out” (either 5)
[…] duplicate
# jan/02/1970 05:33:08 by RouterOS 6.10
/interface wireless
nv2-nstreme-802.11
43CE02EED2CD
/ip hotspot profile
on-login="{\r\
\n }\r\
\n}"
/ip hotspot
/queue simple
add max-limit=50k/1M name=client249 target=192.10.10.249/32
add max-limit=50k/1M name=client250 target=192.10.10.250/32
add max-limit=50k/1M name=client251 target=192.10.10.251/32
add max-limit=50k/1M name=client252 target=192.10.10.252/32
add max-limit=50k/1M name=client253 target=192.10.10.253/32
add max-limit=50k/1M name=client254 target=192.10.10.254/32
add max-limit=50k/1M name=client255 target=192.10.10.255/32
add name=in1 priority=1/1 target=in1
add name=in2 priority=1/1 target=in2
add name=out priority=2/2 target=out
/ip dhcp-client
set servers=8.8.8.8
/ip firewall mangle
add action=mark-connection chain=prerouting connection-state=new disabled=yes \
add action=mark-routing chain=prerouting connection-mark=line2 disabled=yes \
/ip hotspot user
add name=admin
password=0100911
server=hotspot1
server=hotspot1
hotspot1
server=hotspot1
server=hotspot1
server=hotspot1
server=hotspot1
server=hotspot1
server=hotspot1
server=hotspot1
/ip upnp
/system clock
/system leds
/system scheduler
/system script
source="{\r\
\n :global today\r\
\n \r\
\n {\r\
\n }\r\
\n }\r\
\n \r\
\n }\r\
\n }\r\
\n }\r\
\n }\r\
\n}"
You have reverted to one backup? Right. ![]()
I not see one single line of the code I have posted before.
I finded the error (I fix the first post):
I let NAT rules disabled, sorry…
Use this, are “fixed”:
/interface wireless
/system ntp client
rextended you’re awesome ![]()
working fine, thanks
sorry rextended,
just one more request,
how to get Hotspot work on both out(ether5) and wifi
Ehm…
Revert all the changes made, (reload backup) and apply this:
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n bridge-mode=disabled country=egypt disabled=no frequency=2437 ht-rxchains=0,1 ht-txchains=0,1 max-station-count=30 mode=ap-bridge radio-name=HOTSPOT security-profile=default wireless-protocol=802.11
/system ntp client
/interface bridge settings
set use-ip-firewall=yes
add name=bri-hs
/queue simple
set target=bri-hs name=bri-hs [find where name=out]
/ip dhcp-server set interface=bri-hs [find where name=dhcp1]
add bridge=bri-hs interface=wlan1
add bridge=bri-hs interface=out; /ip hotspot set interface=bri-hs [find where interface=out]; /ip address set interface=bri-hs [find where interface=out]
do not split last line!!!
If you not want password for access the wifi (but still needed the password for hotspot):
On wireless / security profile /default you must set on general the “Mode” to “none”
Done.
just receive error in last 3 lines:
/interface bridge ports
bad command name ports (line 1 column 19)
[admin@MikroTik] /queue simple> add bridge=bri-hs interface=wlan1
expected end of command (line 1 column 5)
[admin@MikroTik] /queue simple> add bridge=bri-hs interface=out; /ip hotspot set interface=bri-hs [find where interface=out]; /ip address set interface=bri-hs [find where in
terface=out]
/interface bridge port**s** → /interface bridge port
I fix the script posted before, without loading backup simply complete with that:
thanks rextended, You are very helpful
شكرا ![]()
شكرا للمجاملة!
