Hi!
I have this configuration:
[admin@NTP] > /interface wireless print detail
0 name="wlan1" mtu=1500 l2mtu=1600 mac-address=D4:CA:6D:E1:01:11 arp=enabled interface-type=Atheros AR9300 mode=ap-bridge
ssid="MAG" frequency=2412 band=2ghz-b/g/n channel-width=20/40mhz-eC scan-list=default wireless-protocol=802.11
vlan-mode=no-tag vlan-id=1 wds-mode=disabled wds-default-bridge=none wds-ignore-ssid=no bridge-mode=enabled
default-authentication=yes default-forwarding=yes default-ap-tx-limit=0 default-client-tx-limit=0 hide-ssid=no
security-profile=rad compression=no
security profile:
1 name="rad" mode=dynamic-keys authentication-types=wpa2-eap unicast-ciphers=aes-ccm group-ciphers=aes-ccm
wpa-pre-shared-key="" wpa2-pre-shared-key="" supplicant-identity="" eap-methods=passthrough tls-mode=no-certificates
tls-certificate=none mschapv2-username="" mschapv2-password="" static-algo-0=none static-key-0="" static-algo-1=none
static-key-1="" static-algo-2=none static-key-2="" static-algo-3=none static-key-3="" static-transmit-key=key-0
static-sta-private-algo=none static-sta-private-key="" radius-mac-authentication=no radius-mac-accounting=no
radius-eap-accounting=no interim-update=1m radius-mac-format=XX:XX:XX:XX:XX:XX radius-mac-mode=as-username
radius-mac-caching=disabled group-key-update=5m management-protection=allowed management-protection-key=""
and Radius settings:
[admin@NTP] > /radius print detail
Flags: X - disabled
0 service=wireless called-id="mag1" domain="" address=10.1.0.9 secret="wi" authentication-port=1812
accounting-port=1813 timeout=3s accounting-backup=no realm=""
When I tries connect to mikrotik from phone - I’m not see any attempt to communicate with radius, and see these messages in Log:
17:26:39 wireless,debug wlan1: 00:03:DA:FA:B6:5A attempts to associate
17:26:39 wireless,debug wlan1: 00:03:DA:FA:B6:5A not in local ACL, by default accept
17:26:39 wireless,info 00:03:DA:FA:B6:5A@wlan1: connected
17:26:39 wireless,info 00:03:DA:FA:B6:5A@wlan1: disconnected, 802.1x authentication timeout
What I’m doing wrong?
RouterOS - 6.40.1
WBR,
Fyodor.
