The wifi used to work..
I tried deleting everything and trying the most minimal..
I am currently on 7.15beta9 as I noticed it not working in 7.14.2 but know it was working in 7.14.1..
wifi24 interface is in italics.. and in the dhcp server section it is red with an I for invalid..
Thank you in advance.
> /system/package/print
Columns: NAME, VERSION, BUILD-TIME, SIZE
# NAME VERSION BUILD-TIME SIZE
0 wifi-qcom 7.15beta9 2024-03-27 19:55:08 10.5MiB
1 routeros 7.15beta9 2024-03-27 19:55:08 11.7MiB
> /export terse
# model = C52iG-5HaxD2HaxD
/interface bridge add admin-mac=48:A9:8A:A0:A1:0D auto-mac=no comment=defconf name=bridge
/interface ethernet set [ find default-name=ether1 ] comment=Optimum poe-out=off
/interface ethernet set [ find default-name=ether2 ] comment=Eero
/interface ethernet set [ find default-name=ether3 ] comment=Alpine
/interface wifi set [ find default-name=wifi1 ] configuration.mode=ap name=wifi5G
/interface wifi set [ find default-name=wifi2 ] channel.band=2ghz-ax configuration.country="United States" .hide-ssid=yes .mode=ap .ssid=DefaultSSID disabled=no name=wifi24 security.authentication-types=wpa2-psk
/interface list add comment=defconf name=WAN
/interface list add comment=defconf name=LAN
/ip pool add name=pool88 ranges=192.168.88.100-192.168.88.200
/ip pool add name=pool89 ranges=192.168.89.100-192.168.89.200
/ip dhcp-server add address-pool=pool88 allow-dual-stack-queue=no bootp-support=none interface=bridge lease-time=4h name=server88
/ip dhcp-server add address-pool=pool89 allow-dual-stack-queue=no bootp-support=none interface=wifi24 name=server89
/system logging action set 3 remote=192.168.88.254
/interface bridge port add bridge=bridge comment=defconf interface=ether2
/interface bridge port add bridge=bridge comment=defconf interface=ether3
/interface bridge port add bridge=bridge comment=defconf interface=ether4
/interface bridge port add bridge=bridge comment=defconf interface=ether5
/interface bridge port add bridge=bridge comment=defconf interface=*6
/interface bridge port add bridge=bridge comment=defconf disabled=yes interface=*7
/interface list member add comment=defconf interface=bridge list=LAN
/interface list member add comment=defconf interface=ether1 list=WAN
/interface list member add interface=wifi24 list=LAN
/ip address add address=192.168.88.1/24 comment=defconf interface=bridge network=192.168.88.0
/ip address add address=192.168.89.1/24 interface=wifi24 network=192.168.89.0
/ip cloud set ddns-enabled=yes
/ip dhcp-client add comment=defconf interface=ether1 use-peer-dns=no
/ip dhcp-server network add address=192.168.88.0/24 comment=defconf dns-server=192.168.88.250,192.168.88.250 domain=mktk88.home gateway=192.168.88.1 netmask=24 ntp-server=192.168.88.254
/ip dhcp-server network add address=192.168.89.0/24 dns-server=192.168.89.1 gateway=192.168.89.1 netmask=24
/ip dns set allow-remote-requests=yes cache-max-ttl=1h servers=192.168.88.250
/ip dns static add address=192.168.88.1 comment=defconf name=router.mktk88.home
/ip dns static add address=192.168.88.0 name=network.mktk88.home
/ip dns static add address=192.168.88.255 name=broadcast.mktk88.home
/ip dns static add address=255.255.255.255 name=broadcast
/ip ssh set always-allow-password-login=yes host-key-type=ed25519 strong-crypto=yes
/system clock set time-zone-name=America/New_York
/system identity set name=MkTkX
/system logging add action=remote topics=!dns,!route
/system note set show-at-login=no
/system ntp client set enabled=yes
/system ntp server set enabled=yes use-local-clock=yes
/system ntp client servers add address=192.168.88.254
/tool mac-server set allowed-interface-list=LAN
/tool mac-server mac-winbox set allowed-interface-list=LAN
