Hi Again,
I am using the following openwrt image:
http://openwrt.pantele.com.ua/trunk/metarouter/openwrt-metarouter-rootfs.tgz
All apears to be working fine but i am now trying to install WifiDog into an OpenWrt metarouter instance with not much luck.
I have tried a few wifidog packages from different builds but all show the following error:
root@OpenWrt:/# opkg install http://downloads.openwrt.org/kamikaze/8.09/ar71xx/p
ackages/wifidog_1.1.5-2_mips.ipk
Downloading http://downloads.openwrt.org/kamikaze/8.09/ar71xx/packages/wifidog_1
.1.5-2_mips.ipk
Collected errors:
- Packages were found, but none compatible with the architectures configured
Am i downloading the right packages? which chipset should i be dowloading the package for (ie. ar71xx, ar, atheros etc…)
Has anyone created a wifidog package capable of working with metarouter? or an they ;o)
cheers
