wifiwave wifi2 2.4Ghz fault
that is my hap ax3 → C53UiG+5HPaxD2HPaxD
that is the config export of wifiwave2:
/interface wifiwave2 channel
add band=5ghz-ax disabled=no name=channel5G skip-dfs-channels=all width=20/40/80mhz
add band=2ghz-ax disabled=no name=channel2g skip-dfs-channels=disabled width=20/40mhz
/interface wifiwave2 security
add authentication-types=wpa3-psk disable-pmkid=yes disabled=no management-protection=required name=sec5G wps=disable
add authentication-types=wpa2-psk disable-pmkid=no disabled=no name=sec2G wps=disable
add authentication-types=wpa3-psk disable-pmkid=yes disabled=no management-protection=required name=gsec5G wps=disable
add authentication-types=wpa2-psk disabled=no encryption=ccmp name=gsec2G wps=disable
add configuration=confg5 configuration.mode=ap datapath=datapath_vlan datapath.bridge=bridge-vlan .interface-list=all_lans .vlan-id=none disabled=no mac-address=xxxxxxxxxxxx master-interface=\
    wifi5G name=invitados security=gsec5
add configuration=confg2 configuration.mode=ap datapath=datapath_vlan disabled=no mac-address=xxxxxxxxxxxxx master-interface=wifi2G name=invitados2 security=gsec2
set [ find default-name=wifi2 ] configuration=conf2g configuration.mode=ap disabled=no name=wifi2G
set [ find default-name=wifi1 ] configuration=conf5g configuration.mode=ap disabled=no name=wifi5G
/interface wifiwave2 configuration
add channel=channel5G country=Spain datapath=datapath_lan disabled=no manager=local mode=ap name=conf5g security=sec5G ssid=Mikrotik
add channel=channel2g country=Spain datapath=datapath_lan disabled=no manager=local mode=ap name=conf2g security=sec2G ssid=Mikrotik2
add channel=channel2g country=Spain datapath=datapath_vlan disabled=no manager=local mode=ap name=confg5 security=gsec5G ssid=invitados
add channel=channel2g country=Spain datapath=datapath_vlan disabled=no manager=local mode=ap name=confg2 security=gsec2G ssid=invitados2
/interface wifiwave2 datapath
add bridge=bridge-lan disabled=no interface-list=LANs name=datapath_lan
add bridge=bridge-vlan disabled=no interface-list=all_lans name=datapath_vlan
Interface wifi1, 5GHz, master and slave invitados works well, the interface wifi2 2.4 GHz works… sometimes. I can say it is a authenticating problem.
Thats is happening on a variety of clients, androids, various pcs…
the log;
wireless/debug 4C:D5:77:B5:22:97@wifi2G reauthenticating.
In the mikrotik logs i can see no more. may be you all could tell me how i could extract more info.
That’s the wpa_supplicant log:
# wpa_supplicant -d -c /etc/wpa_supplicant.conf -i wlo1 2>&1 > wpa-s
wpa-s.txt (22.6 KB)
I hope someone could help me with that, i have no more ideas
Thank you!
I just read that having two bridges is not the correct config. I have two because i want to have hardware offloading inside de main lan network. Then I’ve created another bridge for IoT and guests or whatever i want to connect and this way i can use queues on that second bridge.
I have been doing tests with channels, frecuencies, and seems to be all ok. that issue is braking my head badly. Anyway, wifi1 and the slave guest works very well with that config.
It’s that correct?
that’s the complete config.
ax3_conf.txt (13.2 KB)
Right now it has been able to connect. I dont touch anything of the config above. Weird
