Wifiwave2 Canada impossible to use maximum allowed tx-power for 5170-5250 range
So to test this I’m using the hAP ax2, RouterOS version: 7.11beta7 (development)
I noticed that if I set 5GHz frequency on the bottom range of spectrum (5170-5250) I get significantly lower RSSI on my clients than if I use the higher end of spectrum (5735-5895)
interface/wifiwave2/radio/reg-info number=1 country=Canada
ranges: 2402-2472/30
5170-5250/30
5250-5330/24/dfs
5490-5730/24/dfs
5735-5895/30
And I figured that the tx-power gets automatically adjusted to 17 on the 5170-5250 range. For the other range (5735-5895) the tx-power gets automatically adjusted to 26, which is why I get better signals
[admin@MikroTik] > interface/wifiwave2/monitor wlan2
state: running
channel: 5180/ax/Ceee
registered-peers: 0
authorized-peers: 0
tx-power: 17
available-channels: 5180/ax/Ceee
I understand this happens because Canada has a restriction of “License Required for Outfoor & EIRP > 200mW” on the lower range (as the image below is showing)
All my installations are INSIDE, so I should be allowed to transmit at the same power level on both ranges.
I couldn’t find anywhere in the settigns where one can specify “Indoor|Outdoor” installation. So my best hack for now is set Country=“United States”, and try run some sanity checks myself, but would highly prefer to use “Canada” and be able to transmit at 26 on 5170-5250 range.
This problem does not happen on hAP ac2 Router OS v6
Is there something that can be done to solve this problem?
Thank you!
Upgrade ac2 to Ros7 and it will behave the same.
In all seriousness…
Mikrotik has spend quite some effort lately to make sure they are in full accordance with country regulations.
Your workaround is a solution but is a change done under your responsibility.
