Wifiwave2, Capsman and static-virtual
where can i find the setting “static-virtual” in the Capsman menu on a hAP ax³ ? ((Static Virtual Interface; Default: no) CAP will create Static Virtual Interfaces instead of Dynamic and will try to reuse the same interface on reconnect to CAPsMAN if the MAC address will be the same. Note if two or more interfaces will have the same MAC address the assignment from the CAPsMAN could be random between those interfaces.))
THX
