Wifiwave2 CAPsMAN - CAP VLAN configuration fails
i want to configure a hap ax3 as accesspoint with capsman and cap local configured. But i fail, actual the wifi interface won’t start. I have read the manual https://help.mikrotik.com/docs/display/ROS/WifiWave2 and the section CAPsMAN - CAP VLAN. My idea is to use layer2 instead of layer3 how it is solved in the manual. Can anybody help with my configuration? Actual configuration is attached.
ap01_caps_fail.zip (944 Bytes)
Not sure what the problem is, eveyone around here is in love with capsman and says how easy it is…
https://www.youtube.com/watch?v=taQ70m0DVYA&pp=ygURY2Fwc21hbiAgbWlrcm90aWs%3D capsman from MT
https://www.youtube.com/watch?v=1Ct6aJXTE5g&pp=ygURY2Fwc21hbiAgbWlrcm90aWs%3D capsman improved from MT
https://www.youtube.com/watch?v=r2OxOYM0IlQ&t=23s&pp=ygUKd2lmaXdhdmUyIA%3D%3D unlocking wifiwave2 from MT
https://www.youtube.com/watch?v=vkWPlsuyuKE&t=29s how to use 802.11 r with capsman BSS transition from MT
Hello Anav,
thanks for your reply. I found a solution for my problem. My problem was that I did not understand that in addition to the configuration, interfaces also have to be created. These are then applied to the hardware interfaces as a pattern.
