I can’t understand how the channel selection works in Wifiwave2 CAPSMAN…
I’ve setup a site with 12 CapAX controlled by a RB5009 Wifiwave2 CAPSMAN controller, every device has 7.11rc1 ros/firmware and controller has the config:
/interface wifiwave2 channel
add band=2ghz-ax disabled=no frequency=2412,2437,2462 name=channel_2.4_ax width=20mhz
add band=5ghz-ax disabled=no frequency=5200 name=channel_5ghz_ax width=20/40mhz
/interface wifiwave2 datapath
add bridge=lan disabled=no name=vlan100_hotspot vlan-id=100
/interface wifiwave2 security
add authentication-types=wpa2-psk,wpa3-psk disabled=no name=sec1
/interface wifiwave2 configuration
add channel=channel_2.4_ax country=France datapath=vlan100_hotspot datapath.client-isolation=no disabled=no mode=ap name=socoloc_2ghz security=sec1 security.ft=yes ssid=socoloc
add channel=channel_5ghz_ax country=France datapath=vlan100_hotspot disabled=no name=socoloc_5ghz security=sec1 security.ft=yes ssid=socoloc
/interface wifiwave2 access-list
add action=accept allow-signal-out-of-range=1m disabled=no interface=any signal-range=-80..0
add action=reject allow-signal-out-of-range=1s disabled=no interface=any signal-range=-120..-80 ssid-regexp=""
/interface wifiwave2 capsman
set ca-certificate=auto certificate=auto enabled=yes interfaces=lan package-path="" require-peer-certificate=no upgrade-policy=none
/interface wifiwave2 provisioning
add action=create-dynamic-enabled disabled=no master-configuration=socoloc_5ghz name-format=%I_5Ghz slave-configurations="" supported-bands=5ghz-ax
add action=create-dynamic-enabled disabled=no master-configuration=socoloc_2ghz name-format=%I_2Ghz supported-bands=2ghz-ax
Almost all AP take the 2412 frequency, except one or two picking the 2437 or 2462, even CapAX which are a few meters away and in sight.
When I do a frequency usage scan on most of the AP, I can see that 2412 is the most busy channel, and I can see after stopping the scan the “channel reselection”, but I still pick 2412 while 2437 or 2462 would have been the most obvious choice (less networks #, less busy…).
How do this channel selection works in Wifiwave2 CAPSMAN? And is there a way to do a static channel planning without creating multiple provisioning rules?
