wifiwave2 capsman snmp
I’ve some remote sites with Wifiwave2 CAPSMAN and I’m trying to setup NetXMS for monitoring.
I’ve enabled snmp on CAPSMAN router (RB1100AHx4 or RB5009), switch (CRS128 or CRS328) and CAP devices (hAP AC3, hAP AX3, cAP AX…) and can collect interfaces, FDB, routes, etc. But I cannot find any information regarding Wifiwave2 CAPSMAN like remote caps list, registration-table, etc.
Does someone knows the OIDs of Wifiwave2 CAPSMAN? On legacy CAPSMAN it was accessible with OID .1.3.6.1.4.1.14988.1.1.1
You can download MIB file from https://mikrotik.com/download
(all the way down, under General).
Maybe that helps to find what you need ?
I already use the Mikrotik MIB, but Wifiwave2 CAPSMAN doesn’t seems to be implemented.
With legacy CAPSMAN, when you browse .1.3.6.1.4.1.14988.1.1.1, you can see remote caps, registration table, etc. But on a Wifiwave2 CAPSMAN router , the OID is not available, and I cannot find these info anywhere.
In that case you might be better of to create a ticket to support.
Still does not work with RouterOS 7.16.1…
snmpwalk -v2c -c public capsman .1.3.6.1.4.1.14988.1.1.1.6.0
MIKROTIK-MIB::mtxrWlCMRtabEntryCount.0 = Gauge32: 0
And did anyone bother to create a ticket ?
