at this moment I have a setup that works for one SSID (default setup) but there are 3 VLANs on the hAP ax²’s that can’t make contact with their counterparts in the router …
These are the configs.
KING (router):
# 2023-06-26 20:17:17 by RouterOS 7.10
# software id = D87A-VNCJ
# model = RB2011iL
# serial number = HDK08NS38PP
/caps-man channel
add control-channel-width=20mhz frequency=2412 name=VO-2.4-CH01 \
skip-dfs-channels=no
add control-channel-width=20mhz frequency=2462 name=VO-2.4-CH11 \
add control-channel-width=40mhz-turbo frequency=5200 name=VO-5-CH040 \
add control-channel-width=40mhz-turbo frequency=5805 name=VO-5-CH161 \
add control-channel-width=20mhz frequency=2437 name=VO-2.4-CH06
add name=BLUE-BRIDGE
add name=GREEN-BRIDGE
add name=RED-BRIDGE
add admin-mac=48:A9:8A:27:CD:AD auto-mac=no comment=defconf name=bridge-local
set [ find default-name=ether1 ] comment=modem
set [ find default-name=ether2 ] comment=switch
set [ find default-name=ether3 ] comment=Dumpty
set [ find default-name=ether4 ] comment=Humpty
set [ find default-name=ether5 ] comment="Computer Yves (rechtstreeks)"
set [ find default-name=ether6 ] comment=Alarm
/interface vlan
add interface=BLUE-BRIDGE name=BLUE-VLAN vlan-id=10
add interface=GREEN-BRIDGE name=GREEN-VLAN vlan-id=20
add interface=RED-BRIDGE name=RED-VLAN vlan-id=30
/caps-man datapath
add bridge=bridge-local name=VO-Datapath
/caps-man security
add authentication-types=wpa2-psk disable-pmkid=yes encryption=aes-ccm \
group-key-update=1h name=VO-WIFI-Security
add authentication-types=wpa2-psk encryption=aes-ccm name="VO-Guest network"
/caps-man configuration
add channel=VO-2.4-CH01 country=belgium datapath=VO-Datapath mode=ap name=\
"Van Opstal-Wifi configuration-2.4GHz-CH01" security=VO-WIFI-Security \
ssid=Van-Opstal_WL
add channel=VO-2.4-CH11 country=belgium datapath=VO-Datapath mode=ap name=\
"Van Opstal-Wifi configuration-2.4GHz-CH11" security=VO-WIFI-Security \
ssid=Van-Opstal_WL
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=VLANs
/interface lte apn
/ip kid-control
add fri=0s-1d mon=0s-1d name=system-dummy sat=0s-1d sun=0s-1d thu=0s-1d tue=\
0s-1d tur-fri=0s-1d tur-mon=0s-1d tur-sat=0s-1d tur-sun=0s-1d tur-thu=\
0s-1d tur-tue=0s-1d tur-wed=0s-1d wed=0s-1d
add name=dhcp ranges=192.168.1.100-192.168.1.254
add name=BLUE-POOL ranges=192.168.10.100-192.168.10.254
add name=GREEN-POOL ranges=192.168.20.100-192.168.20.254
add name=RED-POOL ranges=192.168.30.100-192.168.30.254
add address-pool=dhcp interface=bridge-local name=local-network-DHCP
add address-pool=BLUE-POOL interface=BLUE-BRIDGE name=BLUE-DHCP-SERVER
add address-pool=GREEN-POOL interface=GREEN-BRIDGE name=GREEN-DHCP-SERVER
add address-pool=RED-POOL interface=RED-BRIDGE name=RED-DHCP-SERVER
/routing bgp template
set default disabled=no output.network=bgp-networks
/routing ospf instance
add disabled=no name=default-v2
/routing ospf area
add disabled=yes instance=default-v2 name=backbone-v2
add channel=VO-2.4-CH01 country=belgium datapath=Gasten-Datapath mode=ap \
name="Gasten-Wifi configuratie-2.4GHz-CH01" security="VO-Guest network" \
ssid=VO-Gasten
add channel=VO-2.4-CH11 country=belgium datapath=Gasten-Datapath mode=ap \
name="Gasten-Wifi configuratie-2.4GHz-CH11" security="VO-Guest network" \
ssid=VO-Gasten
/caps-man datapath
add bridge=*F name=Gasten-Datapath
/caps-man manager
set enabled=yes
/caps-man manager interface
set [ find default=yes ] forbid=yes
add disabled=no interface=bridge-local
/caps-man provisioning
add action=create-dynamic-enabled master-configuration=\
add bridge=bridge-local comment=defconf ingress-filtering=no interface=ether2
add bridge=bridge-local comment=defconf ingress-filtering=no interface=ether3
add bridge=bridge-local comment=defconf ingress-filtering=no interface=ether4
add bridge=bridge-local comment=defconf ingress-filtering=no interface=ether5
add bridge=GREEN-BRIDGE comment=defconf ingress-filtering=no interface=ether6 \
pvid=20
add bridge=bridge-local comment=defconf ingress-filtering=no interface=ether7
add bridge=bridge-local comment=defconf ingress-filtering=no interface=ether8
add bridge=RED-BRIDGE comment=defconf ingress-filtering=no interface=ether9 \
pvid=30
add bridge=bridge-local comment=defconf ingress-filtering=no interface=\
ether10
add bridge=bridge-local interface=BLUE-VLAN pvid=10
add bridge=bridge-local interface=GREEN-VLAN pvid=20
add bridge=bridge-local interface=RED-VLAN pvid=30
set discover-interface-list=all
/ip settings
set max-neighbor-entries=8192
/ipv6 settings
/interface bridge vlan
add bridge=bridge-local tagged=BLUE-VLAN vlan-ids=10
add bridge=bridge-local tagged=GREEN-VLAN vlan-ids=20
add bridge=bridge-local tagged=RED-VLAN vlan-ids=30
/interface detect-internet
set detect-interface-list=all
add comment=defconf interface=bridge-local list=LAN
add interface=BLUE-VLAN list=VLANs
add interface=GREEN-VLAN list=VLANs
add interface=RED-VLAN list=VLANs
/interface ovpn-server server
set auth=sha1,md5
add address=192.168.1.1/24 comment=defconf interface=bridge-local network=\
192.168.1.0
add address=192.168.10.1/24 interface=BLUE-BRIDGE network=192.168.10.0
add address=192.168.20.1/24 interface=GREEN-BRIDGE network=192.168.20.0
add address=192.168.30.1/24 interface=RED-BRIDGE network=192.168.30.0
/ip dhcp-client
add address=192.168.1.0/24 comment=defconf dns-server=8.8.8.8,8.8.4.4 \
gateway=192.168.1.1 netmask=24
add address=192.168.10.0/24 gateway=192.168.10.1 netmask=24
add address=192.168.20.0/24 gateway=192.168.20.1 netmask=24
add address=192.168.30.0/24 gateway=192.168.30.1 netmask=24
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
/ip dns static
add address=192.168.1.1 comment=defconf name=router.lan
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
add disabled=no dst-address=192.168.1.1/32 gateway=BLUE-BRIDGE routing-table=\
main suppress-hw-offload=no
add disabled=no distance=1 dst-address=192.168.1.1/32 gateway=GREEN-BRIDGE \
pref-src="" routing-table=main scope=30 suppress-hw-offload=no \
target-scope=10
add disabled=no distance=1 dst-address=192.168.1.1/32 gateway=RED-BRIDGE \
target-scope=10
add disabled=no dst-address=192.168.10.3/32 gateway=BLUE-BRIDGE \
routing-table=main suppress-hw-offload=no
/routing bfd configuration
add disabled=no
/system clock
set time-zone-name=Europe/Brussels
/system identity
set name="King Richard III"
/system note
set show-at-login=no
/system routerboard settings
set auto-upgrade=yes force-backup-booter=yes silent-boot=yes
/tool graphing interface
add
/tool graphing resource
add
/tool mac-server
/tool mac-server mac-winbox
/tool romon
set enabled=yes
Humpty (hAP ax²):
# 2023-06-26 20:33:18 by RouterOS 7.10
# software id = IJT3-YVDT
# model = C52iG-5HaxD2HaxD
# serial number = HE608PB8KQ0
add name=RED-BRIDGE
add admin-mac=48:A9:8A:6F:1D:11 auto-mac=no name=bridge-local
/interface vlan
/interface wifiwave2 channel
add band=2ghz-n comment="Channel 1" disabled=no frequency=2412 name=\
"VO-Basic Channel setup - 2.4Ghz" skip-dfs-channels=disabled width=20mhz
add band=5ghz-ax comment="Channel 40" disabled=no frequency=5200 name=\
"VO-Basic channel setup - 5GHz" skip-dfs-channels=disabled width=\
20/40/80mhz
/interface wifiwave2 datapath
add bridge=bridge-local disabled=no name=VO-Datapath
/interface wifiwave2 security
add authentication-types=wpa2-psk disable-pmkid=yes disabled=no encryption=\
ccmp group-key-update=1h name="VO-Basic security" wps=disable
/interface wifiwave2 configuration
add antenna-gain=0 country=Belgium datapath=VO-Datapath disabled=no mode=ap \
name="Van-Opstal_WL config" security="VO-Basic security" ssid=\
Van-Opstal_WL
set [ find default-name=wifi2 ] channel="VO-Basic Channel setup - 2.4Ghz" \
channel.frequency=2412 configuration="Van-Opstal_WL config" \
configuration.mode=ap disabled=no name=wifi-2.4GHz
set [ find default-name=wifi1 ] channel="VO-Basic channel setup - 5GHz" \
channel.frequency=5200 configuration="Van-Opstal_WL config" \
configuration.hide-ssid=no .mode=ap disabled=no name=wifi-5GHz
add configuration.mode=ap .ssid=BLUE-WIFI datapath.vlan-id=10 disabled=no \
mac-address=4A:A9:8A:6F:1D:16 master-interface=wifi-2.4GHz name=BLUE-WIFI \
add configuration.mode=ap .ssid=GREEN-WIFI datapath.vlan-id=20 disabled=no \
mac-address=4A:A9:8A:6F:1D:15 master-interface=wifi-2.4GHz name=\
GREEN-WIFI security="VO-Basic security"
add configuration.mode=ap .ssid=RED-WIFI datapath.vlan-id=30 disabled=no \
mac-address=4A:A9:8A:6F:1D:17 master-interface=wifi-2.4GHz name=RED-WIFI \
/ip kid-control
/zerotier
set zt1 comment="ZeroTier Central controller - https://my.zerotier.com/" \
name=zt1 port=9993
/zerotier interface
add allow-default=no allow-global=no allow-managed=yes disabled=no instance=\
zt1 name=van-opstal-zerotier network=db64858feded82f0
/dude
set enabled=yes
add bridge=bridge-local comment=defconf interface=ether2 pvid=99
add bridge=bridge-local comment=defconf interface=ether3 pvid=99
add bridge=bridge-local comment=defconf interface=ether4 pvid=99
add bridge=bridge-local comment=defconf interface=ether5 pvid=99
add bridge=bridge-local comment=defconf interface=wifi-5GHz pvid=99
add bridge=bridge-local comment=defconf interface=wifi-2.4GHz pvid=99
add bridge=BLUE-BRIDGE interface=BLUE-WIFI pvid=10
add bridge=GREEN-BRIDGE interface=GREEN-WIFI pvid=20
add bridge=RED-BRIDGE interface=RED-WIFI pvid=30
/ipv6 settings
set max-neighbor-entries=15360
add bridge=bridge-local tagged=BLUE-BRIDGE vlan-ids=10
add bridge=bridge-local tagged=GREEN-BRIDGE vlan-ids=20
add bridge=bridge-local tagged=RED-BRIDGE vlan-ids=30
/interface wifiwave2 access-list
add action=accept comment="GSM Rosalie" disabled=no interface=any \
mac-address=46:59:2E:8E:05:E0
add action=accept disabled=no interface=any mac-address=18:69:D8:01:5E:8B
add action=accept disabled=no interface=any mac-address=30:8E:7A:7A:4E:AC
add action=accept disabled=no interface=any mac-address=60:FB:00:38:CE:2F
add action=accept disabled=no interface=any mac-address=68:57:2D:DD:4D:7C
add action=accept disabled=no interface=any mac-address=84:7A:B6:15:89:A3
add action=accept disabled=no interface=any mac-address=B4:FB:E3:DF:42:6D
add action=accept disabled=no interface=any mac-address=B4:FB:E3:E0:02:29
add action=accept disabled=no interface=any mac-address=B4:FB:E3:EE:6F:38
add action=accept disabled=no interface=any mac-address=D4:A6:51:29:D9:51
add action=accept disabled=no interface=any mac-address=D4:A6:51:F2:C9:59
add action=accept disabled=no interface=any mac-address=DC:A6:32:4A:E9:E5
/interface wifiwave2 cap
set certificate=request discovery-interfaces=bridge-local enabled=yes \
slaves-datapath=VO-Datapath
/interface wifiwave2 capsman
set package-path="" require-peer-certificate=no upgrade-policy=none
add address=192.168.1.2/24 interface=bridge-local network=192.168.1.0
add address=192.168.10.2/24 interface=BLUE-BRIDGE network=192.168.10.0
add address=192.168.20.2/24 interface=GREEN-BRIDGE network=192.168.20.0
add address=192.168.30.2/24 interface=RED-BRIDGE network=192.168.30.0
/ip dhcp-client
add interface=bridge-local
/ip dns static
add action=accept chain=input connection-state=established
add action=accept chain=input connection-state=related
add action=drop chain=input in-interface-list=!LAN
add action=fasttrack-connection chain=forward connection-state=\
established,related hw-offload=yes
add action=accept chain=forward connection-state=established,related
add action=passthrough chain=unused-hs-chain comment=\
"place hotspot rules here" disabled=yes
/ip upnp interfaces
add interface=bridge-local type=internal
add interface=ether1 type=external
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/system clock
/system identity
set name=Humpty
/system note
/system scheduler
add comment="reboot om te verhinderen dat wifi plots wegvalt." disabled=yes \
interval=12h name="herstart elke avond" on-event="daily reboot" policy=\
reboot start-date=2023-05-14 start-time=16:30:01
add
/tool mac-server
/tool romon
set enabled=yes
and finaly Dumpty (hAP ax²):
# 2023-06-26 20:33:14 by RouterOS 7.10
# software id = HH4P-3WY5
# serial number = HE908HQCE0T
add name=RED-BRIDGE
add admin-mac=48:A9:8A:92:7B:FF auto-mac=no comment=defconf name=bridge-local
/interface vlan
add band=2ghz-n comment="Channel 11" disabled=no frequency=2462 name=\
add band=5ghz-ax comment="Channel 161" disabled=no frequency=5805 name=\
20/40/80mhz
add antenna-gain=0 country=Belgium disabled=no mode=ap name=\
"Van-Opstal_WL config" security="VO-Basic security" ssid=Van-Opstal_WL
channel.skip-dfs-channels=10min-cac configuration="Van-Opstal_WL config" \
configuration.mode=ap disabled=no name=wifi-2.4GHz security=\
"VO-Basic security"
channel.frequency=5805 .skip-dfs-channels=10min-cac configuration=\
"Van-Opstal_WL config" configuration.mode=ap disabled=no mtu=1500 name=\
wifi-5GHz security="VO-Basic security"
mac-address=4A:A9:8A:92:7C:04 master-interface=wifi-2.4GHz name=BLUE-WIFI \
add configuration.mode=ap .ssid=GREEN-WIFI disabled=no mac-address=\
4A:A9:8A:92:7C:05 master-interface=wifi-2.4GHz name=GREEN-WIFI security=\
"VO-Basic security"
add configuration.mode=ap .ssid=RED-WIFI disabled=no mac-address=\
4A:A9:8A:92:7C:06 master-interface=wifi-2.4GHz name=RED-WIFI security=\
"VO-Basic security"
/ip kid-control
/zerotier
name=zt1 port=9993
/zerotier interface
/dude
set enabled=yes
/ipv6 settings
add action=accept comment="GSM Yves" disabled=no interface=any mac-address=\
6A:5E:79:C2:14:C5
add action=accept comment="Tablet Yves" disabled=no interface=any \
mac-address=78:40:E4:1E:41:02
add action=accept comment="Laptop Astrid" disabled=no interface=any \
mac-address=68:57:2D:DD:2F:2E
add action=accept comment="Laptop Rosalie" disabled=no interface=any \
mac-address=2C:8D:B1:AD:CA:C8
add action=accept comment="laptop Petra" disabled=no interface=any \
mac-address=8C:C8:4B:38:7A:D7
add action=accept comment="GSM Petra" disabled=no interface=any mac-address=\
4E:3D:E2:D3:AA:87
set discovery-interfaces=bridge-local enabled=yes slaves-datapath=VO-Datapath
add address=192.168.1.3/24 interface=bridge-local network=192.168.1.0
add address=192.168.10.3/24 interface=BLUE-BRIDGE network=192.168.10.0
add address=192.168.20.3/24 interface=GREEN-BRIDGE network=192.168.20.0
add address=192.168.30.3/24 interface=RED-WIFI network=192.168.30.0
/ip dhcp-client
/ip dns static
invalid
invalid
icmpv6
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
ipsec-ah
ipsec-esp
!LAN
/system clock
/system identity
set name=Dumpty
/system note
/tool mac-server
/tool romon
set enabled=yes
