a few questions regarding Wifiwave2 I couldnt figure out.
I run a few cAPac as default-installed CAPs with a default-CAPSMAN. Now I want to replace the cAPac step-by-step with cAPax.
My CAPSMAN runs on a CCR2004 with ARM64. This sentence is not clear to me:
Builds for x86, ppc, mmips and tile architectures contain the configuration utilities needed to centrally manage interfaces (as a CAPsMAN controller). Builds for arm and arm64 also contain interface drivers and firmware.
Do builds for arm64 (my CCR2004) contain the CAPSMAN-controller too or only drivers?
And can I run CAPSMAN and CAPSMAN-WifiWave2 on the same physical router? In a way CAPSMANv1 on port XXXX and CAPSMANv2 on port YYYY?
Or can I simply run the cAPax with the “old” CAPSMAN?
